Need some help in Issaquah
Hey guys! I'm looking for some help installing a fuel pump in a 98' Dodge Stratus... Tyler and I could probably do it, but would definitely feel more comfortable if someone that has experience with dropping a tank and installing a fuel pump would help, or even do the work, I will pay.
I know that the tank needs to be dropped to install it, its effing HUGE (the pump), The tank location on this car is in front of the rear axle, and the pump location is in the driver side rear of the tank. We double checked that there was no easier way to do this, but there isn't, sadly the tank will need to be dropped, the other issue is this car is sitting in a gravel shoulder across from the owners house, it doesn't run so we would need to do the work there, Tyler and I have already jacked the car up once before to do a fuel filter install (started with cheapest parts and worked up) so we know the ground there is strong enough to support the vehicle, I have an easy-up tent for use if its raining, and I will be in attendance of the install to help out wherever possible.
I'm currently unemployed so any time any day works for me
hop this works out for you...if you want added support underneath the jack stands get some steel plates or even some 2X4's.
you will do much better and have an easier time if you siphon the tank first...you wouldn't believe how heavy and awkward a tank full of gas can be to maneuver because of how wide the tank is....
disconnect the battery before you even attempt this and make sure that all the lines that attach to the tank are plugged with something and disconnected from the tank completely. thn you will need to look for the straps that hold the tank up.. if you drained the gas the tank will be fairly light and easy to get out of place.
im guessing it will be maneuverable out of the way of the rear suspension.
hope this helps
hope this helps
hope this helps
hope this helps
helps bunch pete! thank you...do you have any advice for disconnecting / not breaking the hard lines?
May and I want to give a HUGE thanks to Brian Zinn for taking time on his vacation to drive ALLLLL the way up here to Issaquah to install a fuel pump for us, and also a BIG thanks to Will too for coming along with Brian and helping as well. THANK YOU BOTH SOOOOOOO MUCH, you have no idea how much this was needed.
Yeah Brian, thanks a bunch for lending a hand to Josh on this, it's what we're all about, wish I could have stayed to help ya'll!
Can't believe it's been so long since we've seen each other, geez. The Yaris is going to be insane!
Yeah tell Eric about what I said about drilling into the bar,putting a tube sleeve in weld it in place then you can pass the bolt through for a harness....thats how they do it in a cage should work fine on a bar.....
Ok so my fridge looks like a bachlors...the entire bottom shelf is full of Miller High lifes......like 44 of them......then there is an empty gallon milk,some burrito shells,salsa,some really old chili in a tupperware that is gonna not be safe for humans......ketchup and coffee creamer.....
I think a trip to the grocery store is in order....lol
NWMotoring
Regional - Pacific Northwest
19
Mar 29, 2010 11:18 PM
Asmar
116
Mar 4, 2010 04:52 AM
AWDios
22
May 21, 2007 08:24 PM
CelicaGirlGT94
41
Sep 10, 2006 08:52 AM
