noisy1eh
03-19-2011, 01:21 AM
Goodday all,
I am looking to rewire my fog lights so they come on with the marker lights and stay on when the high beams are on.
Has anyone seen or have a diagram of the lighting to see what i need to jumper or change the grown path ?
Thanks
cement
03-20-2011, 03:10 AM
the light switch is ground controlled. the fog light relay does not have any power at all when the headlight switch is off. once the headlight is on, the fog light switch gets power AND ground from the headlight circuit. in order for you to have the fog lights on with the marker lights, the relay has to get constant power by tapping the power wire to the relay to a positive source. for the ground side, that needs to be tapped into the ground switch for the marker lights. that way when the markers are off, the fog lights will turn off too.
i know this is very vague. im just trying to give you an idea on how the system works. once i do this to mine, i'll make a DIY...
noisy1eh
03-20-2011, 10:13 AM
Thanks
If You do it Please do a DIY i would love to see it.
