Over-rev
Old Mar 21, 2011 | 10:03 AM
PoBoyxB's Avatar
Default Over-rev
Anyone ever overrevved their 1nz? Like, really bad? Somehow I managed to hit 2n gear instead of 4th and it sung a note I'd never heard before. Since the tach only goes to 7k, I really don't know how high it got, but it was higher than that. Now it will barly run at an idle. I had a set of plugs that I threw in and it didnt make a difference. Checked injectors: good. Checked valve springs: good. It's down to either piston rings or head gasket...
Old Mar 21, 2011 | 10:16 AM
Roller_Toaster's Avatar
check around google to see if its a non-interference head. If it IS a non interference head,you're ok.
It could also be your valves themselves....that's usually what gets damaged in an over-rev.
Old Mar 21, 2011 | 12:35 PM
PoBoyxB's Avatar
Yea, that was another thought of mine
Old Mar 21, 2011 | 12:59 PM
well, I've found lots of posts from people SAYING its a non-interference...but no real data to back it up.
Old Mar 21, 2011 | 02:05 PM
draxxus0321's Avatar
Music City Scions
i did the same thing in my tC the best thin gto do is run a compression test on all 4 cylinder. i ran it on mine and found out i have bent valves so im in the process of getting that fixed
Old Mar 21, 2011 | 03:32 PM
PoBoyxB's Avatar
That's the plan when I get home from work today...I wonder if anyone has a 2zz laying around
Old Mar 21, 2011 | 04:51 PM
Reactor's Avatar
If you floated the valves then the intake ones may got bent. Need to do compression or even better the cylinder leakdown test. Did you check the manifold vacuum?
Old Mar 21, 2011 | 07:24 PM
PoBoyxB's Avatar
I plan on doing the compression test when I get off work. I ran out of daylight and energy yesterday. It's more than likely bent valves. When I pull the injector or spark plug off the #3 cyl, it makes no difference in how it idles. And very little difference on the #2 cyl
Old Mar 21, 2011 | 08:41 PM
cmcpride's Avatar
valve floated for sure. i had the same thing happen to me last month. the good thing its a 1nz it sould take you about a few hours to R&R good luck.
Old Mar 21, 2011 | 11:09 PM
PoBoyxB's Avatar
Where did you get your valves?
Old Mar 22, 2011 | 07:10 PM
PoBoyxB's Avatar
bent all the exhaust valves, looks like the intake valves might be alright. should find out for sure tomorrow.
Old May 29, 2011 | 12:00 AM
roundheya's Avatar
That's odd, what was your sPeed?
I've gone from 107 into second rather than fourth on a gm vehicle before with zero damage, and my box motor has taken twice the punishment that motor ever did.
