Built motor w/ turbo need clutch!
Old Mar 28, 2011 | 08:30 PM
craftedinsane's Avatar
Default Built motor w/ turbo need clutch!
i have a exedy stage 2 thats slips after 4k rpms. i got upgraded rods and pistons with balance shaft delete and a custom turbo kit. before the engine build i was pushing 289whp then when i put the new motor in, the clutch slipped bad on the dyno and i could only get a tune up to 4k rpms, so it either slips or a/f goes crazy. i got a budget of $500 for a new clutch, any advise?
Old Mar 28, 2011 | 08:39 PM
helloninja's Avatar
I have an ACT modified street disk, it is a little over kill for most NA but should work great for what you have. It is rated at 390 Tq and is right in your budget. Do you plan on running high boost later?
Old Mar 28, 2011 | 08:54 PM
no high boost for me, thats why i had to rebuild the motor, i blew a piston ring and i went all out to make sure it didnt happen again. i had no intentions in building my motor but i wanted to keep boost. i want to sit pretty at 15 psi and low 10. i blew the motor at 8psi in 4 months. thank you!
Old Mar 28, 2011 | 08:57 PM
the modified street looks to be the most expensive out of the 6 puck and 4 puck, hd street is 100 dollars cheaper and ratings are the same, is there really a big difference in them?
Old Mar 28, 2011 | 09:51 PM
emrules2001's Avatar
HD street is all you need. I have that on my Dezod turboed tC at 7psi, and im pushing 260 hp. It has stock-like engagement, but stiffer pedal pressure. Had it for a year with 0 problems, even with my mis-shifts
Old Mar 28, 2011 | 09:57 PM
aparreira9586's Avatar
https://www.scionlife.com/forums/sho...d.php?t=200652
Old Mar 28, 2011 | 11:18 PM
any1 think i should get the 6 puck used clutch with new pressure plate without throwout bearing?
Old Mar 30, 2011 | 01:21 AM
SB08tc's Avatar
What brand of six puck? I know I have a ACT and i had to use the OEM throwout bearing.
vi3tb0i09
Sep 23, 2015 08:32 PM
brett561tc
Sep 15, 2015 06:33 AM
stenger
Jul 15, 2015 01:03 AM
