*Help**
Old Mar 30, 2011 | 04:07 AM
P33zy05tC's Avatar
Default *Help**
Ok recently I was riding downtown in my 05 tC and I hit a huge pot hole, and now my double din doesnt work anymore I checked the fuses under the hood, and in the car they all seem to be fine.... also while trying to figure that out today I removed the center dash trim kit, and when i pieced it back together all of a sudden my heat doesnt turn on, windows doesn't roll down, and signals dont come one please helpp!!!
Old Aug 18, 2011 | 03:39 AM
s_rhabb's Avatar
Team Scionara
Any luck with fixing that problem, I'm going through the same thing.
Old Aug 18, 2011 | 04:41 AM
P33zy05tC's Avatar
Yea, I figured that the two fuses in the back of my indash had blew due to the impact of the bump. As far as the hvac heating I had to replace the fuses as well.. I just tested all the fuses & replaced all the ones that were blown with brand new ones. Once I did that everything was working back normal.. Dot try to guess & look to see which fuses are good as which are blown actually test them & the same exact way u remove it put it back in that way any other questions or extra help just reply.....
Old Aug 18, 2011 | 06:09 AM
s_rhabb's Avatar
Team Scionara
Can you remember at all which fuses you ended up replacing? I cant find the fuses for the hvac. I pulled the fuses for my tail lights, ignition, signal/hazard lights and a few others and they were not blown. list what you can that you replaced. Thanks.
Old Aug 18, 2011 | 07:17 AM
Zsanz's Avatar
do they light up? but just dont come on ?
Old Aug 18, 2011 | 12:20 PM
s_rhabb's Avatar
Team Scionara
The hazard lights work but when you turn on the signal lights (left or right) absolutely nothing happens.
Old Aug 18, 2011 | 03:14 PM
P33zy05tC's Avatar
Nope I don't remember which onea it was for the hvac simply because I just cleaned house.. If u still have your owner Manuel it'll tell u the lay out for the fuses underneath the drivers panel... Don't take it to electric shop it'll be a waste of money.. Youre better off replacing every fuses that under there, but it is frustrating you just have to have the right fuse tester.
