WR SW with AlfaWerks TB?
Old Mar 15, 2005 | 03:26 AM
ToBeeyach's Avatar
Default WR SW with AlfaWerks TB?
So my question is this: I'm getting the Weapon-R Secret Weapon intake. If i decide to get the AlfaWerks Throttle Body later on down the road, what kind of adjustments would i have to make? would i need some kind of adapter?
Old Mar 15, 2005 | 04:15 AM
WeaponR_Ray's Avatar
It is dependant on the outer diameter of the new TB. Our reducer will stretch up to 2.75". Larger than that you will need a new straight 3" coupler.
Old Mar 15, 2005 | 04:36 AM
English's Avatar
How big is the AlphaWerks throttle body?
Old Mar 15, 2005 | 04:38 AM
KYBoy's Avatar
Scion Corps
DeepSouth Scions
60mm
here is the link
http://www.alphawerks.com/alpha_frameset_throttle.htm
Old Mar 15, 2005 | 04:57 AM
English's Avatar
jeez 450 I don't think that's worth it... and you need a core exchange???
Old Mar 15, 2005 | 05:15 AM
KYBoy's Avatar
Scion Corps
DeepSouth Scions
different ones will come out by other companies , just have to wait for them.
hopefully they will be less expensive
Old Mar 15, 2005 | 06:01 AM
60mm is the inner diameter, you will need to know the outer diameter.
Old Mar 15, 2005 | 06:14 AM
English's Avatar
well I think 60mm~2 inches so it shouldn't be a problem fitting the adapter if it goes up to 2.75 inches which is like, 82.5mm I think so it should not be a problem
Old Mar 15, 2005 | 06:46 PM
60mm is the diameter of the INSIDE of the TB, and has nothing to do with the outside of the TB, where the coupler actually clamps onto.
Anyways though, it should be the same as stock, since they require a core exchange, it's just a bored out stock TB.
Old Mar 16, 2005 | 04:16 AM
sl0wp0ke's Avatar
Ummm just fyi, I would not buy the TB it put out 1hp 1tq. Waste of money.
Old Apr 3, 2005 | 04:29 AM
tckurt's Avatar
N.G.S.O.
are you joking only 1hp and 1tq... that sucks.
Old Apr 3, 2005 | 09:37 AM
daewonder's Avatar
is there a dyno that shows the 1hp/1tq gain? didn't the alphawekrs tC with i/h/e/tb dyno +29 hp? the tb only made 1 of the 29?
Old Apr 3, 2005 | 03:59 PM
RacingSolution's Avatar
Strictly Scionized
alpha werks will most likely not be producing it because it did not make much power at all.
Old Apr 4, 2005 | 07:48 AM
hahaitzskippy's Avatar
mayb the TB produced 1hp 1tq ALONE... with no other aftermarket parts?
mayb with an intake, itll make 2-4? with exhaust... 3-5? i dunno. jus my .02
