Transmission Flush/Change Questions
Old Apr 14, 2011 | 12:03 AM
TRD-Chris's Avatar
Default Transmission Flush/Change Questions
Hello, just have a few questions regarding transmission maintenance.
-Whats the best position to drain the transmission fluid? Will having 2 jacks at the front be sufficient to drain the necessary fluid or is it best to have it leveled and go the extra mile to jack the rear as well.
-Same question when filling, is it best leveled or it doesnt matter, the front jacked up is fine?
-Hot or Cold..is it best to have the Trans fluid hot when replacing (like changing motor oil) or it doesnt matter..can it be cold?
Old Apr 14, 2011 | 01:32 AM
tipc4life's Avatar
it dosen't matter which way you do it just make sure you shift through the gears when you refill it make sure its smooth if not add as need till it gos away.
Old Apr 15, 2011 | 03:00 PM
Im2c0oL's Avatar
I changed my fluid with Redline MT-90 at 35k with just the front jack up, I believe it should be completely drained out that way too. make sure you torque the fill and drain plug back to spec, and remove the top sensor to fill is the best way!!! good luck!!!
My fill bolts got loose and I lost a quart of MT-90 in there, and it's kind of difficult to buy those locally, so I retighten the fill screw and drove my car for about 20k already, finally I just bought a bottle of Mobile 1 Synthetic, 24mm socket and 1 1/16th socket. I just fill it with the 1.7qt MT-90, and with the Clutch stopper mod, boy my car feels more like a new car, I love driving it my car more now...
Old Apr 15, 2011 | 04:58 PM
TRD-Chris's Avatar
Thanks for the tips guys, im actually doing it in 15mins lol. After that I'll look into the clutch stopper mod that you spoke of Sw07tC.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
elzy0000
Jan 16, 2004 04:31 PM
