View Full Version : new to turbo got questions..
jtk2
05-16-2011, 03:19 AM
ok ive never had a turbo before and know very little about them. but its time to get one..im tired of being beat everywhere i go.. my questions are with the descendant turbo..
1. whats the difference in getting the engine management system and not getting it? (what does that do)
2. and getting this turbo..will the stock engine support it? or do i need to do some internals first?
3. how much would it cost to install with a tune?
Papa_Bear
05-16-2011, 03:31 AM
1. Some people do not get the engine management because they want to use a different form of engine management however with boost you NEED engine management.
2.Stock internals on their preprogrammed maps are completely fine. They told me the stock internals will support 350 whp so no internals are needed.
3. I am going to work on getting their turbo as well as detailed instructions installing this so you might have my video to guide you through it. You don't need a tune with their turbo kit as long as you get the full kit as it comes with the proper preprogrammed maps.
Anything else you can email/call me corey@obnoxiousperformance.com or get my number from my site :)
jtk2
05-16-2011, 03:36 AM
sweet thanks man! yea ill be looking for that video. to see how difficult it is..
ZeroEyeQueue
05-16-2011, 04:27 AM
The Descendant kit is a bolt-on and go system. However, they did recommend a tuning on a dyno beyond the base maps. The base maps will get the car running with a good amount of hp and no cel's, but you'll want to fine tune it. Descendant uses church's dyno, which is below sea level, apparently, which gives them different gains. Especially if you're like me who is no where near Torrence, CA and have very different weather, you'll want a fine tune for optimal gains.
A couple shops have quoted a shiny penny for installs. I can only speak for the SE Michigan area on prices. 900$ if their labor isn't cheap. Reason being most aftermarket shops have an 8 hour work day and labor is about 90/hr. If you want to avoid this, install it yourself, or with someone that has a cursory knowledge of auto maintenance and assembly. The lists of tools and materials are short.
Dyno time and tuning ranges anywhere from 200+ depending on what you want and how many presets you want. Or, you can tune it yourself by doing pulls on the street (disclaimer: Dangerous, I don't recommend this.). It helps if you install a wideband O2 sensor. I went with the AEM UEGO controller, since the piggyback system itself is made by AEM.
Just remember, the turbo is a complete kit, but there are things here and there you'll need to buy to install it, however small it may be (stuff for fluid changes, teflon tape, etc.).
The install itself is almost identical to the xB install:
http://www.youtube.com/watch?v=iXW_wvslbE0&feature=player_embedded
jtk2
05-16-2011, 04:44 AM
thanks dude. yea ill probably just take it to a shop and get it professionally done with a tune.
speedy000
05-16-2011, 06:18 AM
you in houston u have the best tuner in texas in your back yard! hit up chris (crush) in the regional forums and he will help u out! HIS WORK ROCKS!
Prototype_xB
07-01-2011, 06:01 PM
1) Engine management is a MUST. Simply slapping a turbo on will not increase power. The increase in power is due to the additional fuel that is supplied to the mix that is able to be burned efficently in compressed air. Compressed air-> more o2, more o2-> more fuel, more fuel-> more power.
In order to supply this extra fuel you need to go beyond what the stock computer will allow and in order to do this you will need a device either inline, piggybacked, or a totaly replacment to the stock computer as well as larger injectors that will step up your ability to supply fuel. Then on top of that which ever way you go will need to be tuned to your particular setup. Tunning involves adjusting fuel/timing either by rpm windows or globaly to achieve a desired air fuel ratio under load.
2)The gen 1 tC's have proven themselves strong enough to handle a decent amout of boost/power over a great deal of time. However, this relies heavily on how spot on and conservative your tune is. Don't know much about the new gen 2's since they come out because i've moved on to other specialties but i believe it would be safe to say reliability and strenght shouldn't be a problem. A good safe tune along with maintenance and personal knowledge is the key to keeping anything running.
3)Install costs really vary from shop to shop. You will have to find a shop that you feel comfortable with. Dyno tuning again vary from one location to another. The overal average is $100 per hour, or $300 for an initial tune.
cubano4ever
10-03-2011, 05:08 AM
you will need a engine management to run a turbo .. and and installation u can do it yourself and tune it can be from 350 to 500
