*LEDmod.com xB2: Custom High Power 54/30 LED Domelight and Maplight
Scion xB2 : Custom High Power 54 LED Domelight and Maplight
Using high power 3-chip SMD LED technology
To order please click here for the link
Connect the socket, check to make sure it lights up(if it does not light up, flip the connection)
Peel off the adhesive film
Tuck the wires and stick it on, double check the light and put the lens back on
Remove the lens using flat head screw driver (there is small notch)
Connect the socket, check the light (if it doesn't light up, flip the connection)
Apply two layer of foam tape to secure the LED module and tuck the wires
Put the lens back on, check the light and align the module as needed
- Rear Domelight 54 LED(14 x 3-chip) : 5.0" x 1.5"
- Front Maplight 30 LED(10 x 3-Chip) : 1.5" x 1.5" [Comes as pair, two module for the maplight]
- Flexible super thin SMD design, 1/16" thick
- One of the brightest in the market
- Harness is design to fit the stock socket
- Plug and Play style installation
- Double sided tape for easy installation
- 1-year warranty
- All colors available : White, Blue, Red, Green
Installation Guide
Remove the lens using flat head screw driver (there is small notch)Connect the socket, check to make sure it lights up(if it does not light up, flip the connection)
Sub-Total: $76.96
You can place an order from here..
http://store.ledmod.com/index.php?ma...products_id=68
daniinpitt
04-04-2015 08:07 PM
CONCRETETC
02-09-2015 08:05 PM
TheTripleC
01-04-2015 06:46 PM
