Original tires finally going out... suggestions?
Old May 24, 2011 | 08:52 PM
Skeenis's Avatar
Question Original tires finally going out... suggestions?
I have a 2009 xD with 35,000 miles. My tires are wearing really low and it is time to change.
Do you suggest Pirelli or Goodyear? I am leaning toward the 205/55-16.
Old May 24, 2011 | 09:28 PM
CXTKRS1's Avatar
Looking for performance or comfort and what is your budget?
Old May 24, 2011 | 09:50 PM
Skeenis's Avatar
Comfort. I'm not a racer, I'm a saver. I value quality, especially when it comes to safety. Don't really need to be excessive, though. Hope that makes sense.
Old May 24, 2011 | 10:26 PM
CXTKRS1's Avatar
Then I recommend the Michelin HydroEdge, excellent comfort while awesome wet weather traction. The tire comes with a 90K warranty and if you take care of them expect to see 100K plus out of these tires.
Old May 24, 2011 | 10:29 PM
CXTKRS1's Avatar
http://www.tirerack.com/tires/tires....omCompare1=yes
Link with reviews.
Old May 25, 2011 | 01:19 PM
Skeenis's Avatar
Thanks!
Old Aug 3, 2011 | 03:56 AM
Bobielon's Avatar
90k miles, thats rad.
Old Aug 3, 2011 | 12:13 PM
mikem53's Avatar
I can't agree.. Michelin makes a great tire.. but I wouldnt want one that lasts that long.. They are going to be hard.. which is why they last so long..
In a small lightweight car like the xD.. you want a tire with some give..
One that won't be hard and amplify every bump and rough surface..
I would go with something more conventional that will give you 40 - 50K wear and still be compliant enough for a nice ride.. Look around .. there are plenty of good choices..
Old Aug 5, 2011 | 05:52 PM
GreyFox's Avatar
My xD is getting new tires installed now. Looking for a tire with less road noise and a good warranty. So I'm getting Bridgestone Turanza with Serenity technology 205/55 R16 91H hope they work out for me. The size change will make the speedo 1mph less indicated and alter the odometer
Old Aug 5, 2011 | 06:46 PM
Roller_Toaster's Avatar
General JUST released an amazing tire...
http://www.motortrend.com/womt/1103_..._03/index.html
Old Aug 22, 2011 | 07:35 AM
CXTKRS1's Avatar
Thread is fairly hard but the sidewalls do a pretty good job of absorbing energy since they are so soft (the tires are usually T rated). I know most Michelin tires are covered under a 30 day try and buy kinda thing so if you do not like them they can be returned and you avoid a restocking fee.
Old Sep 29, 2011 | 02:18 AM
lostxD's Avatar
hey, i'm thinking about purchasing the michelin hydroedge with green x tires.
can someone point me to the most appropriate size for stock steelies?
Old Sep 29, 2011 | 02:36 AM
CXTKRS1's Avatar
They are not made in the stock 195/60/16 size and the closest size I know of is 205/55/16. 215/55/16 and 225/50/16 will also fit but they are performance sizes so I'm not sure if the Hydroedges are made in that size.
Old Sep 29, 2011 | 11:41 PM
lostxD's Avatar
thanks,
will be ordering from tirerack. lets hope these will outlast the crappy dunlops oe. only got 31k miles from them
Old Sep 29, 2011 | 11:46 PM
lostxD's Avatar
tirerack has 215/55/16. i don't think they have 205/55/16.
Old Sep 30, 2011 | 02:51 AM
lostxD's Avatar
nvm found 205/55/16 on the site, thanks
Old Oct 2, 2011 | 03:29 AM
CXTKRS1's Avatar
thanks,
I have the Bridgestone EL-400's and will probably on get 25K out of them.
Old Oct 16, 2011 | 02:44 PM
inkblotter11's Avatar
i also have (extensively) shopped 205/55/16s. here is my go to list, based on budget and performance (prices are from various online sources). don't need any snow tires:
TIRE/PRICE/WEIGHT IN LBS
*Conti DW $106, 19
*Ventus v12 $89, 19
Proxes 4 $112, 20
*conti DWS $110, 21
Yoko AD08 $140, 21
Ziex 512 $? , 21
Pilot Exalto PE2 $150, 21
Toyo T1R $165, 21.9
BStone RE760 $112, 22
Yoko S.Drive $95, 23
Dunlop Starspec $114, 24
FK452 $110, 24
* = My faves/ the ones i will most likely purchase in the future.
I read over tire reviews often for owner tips and impressions. some like the conti's require added PSI for better turning performance, for ie.
Old Oct 17, 2011 | 01:46 AM
CXTKRS1's Avatar
I work at a tire shop and for some reason I have had always had horrible luck with the Conti's.
Old Oct 24, 2011 | 04:10 PM
would you mind elaborating? i am particularly interested in extreme contact dw and dws. failures? flaws? other issues? thanks
