matrix_XB
06-08-2011, 04:34 AM
I just do my xb turbo and when I went up in lights traction control and I can not activate this is common?
View Full Version : problem on my turbo wagon...help matrix_XB 06-08-2011, 04:34 AM I just do my xb turbo and when I went up in lights traction control and I can not activate this is common? sp2 06-08-2011, 04:37 AM Sorry but write this more clearly and detailed or no one will know can help. Pasquale 06-08-2011, 04:54 AM exactly what is the car doing? it wont turn over...wont pull out of 2500rpm's so on and so on? matrix_XB 06-08-2011, 05:53 AM what happens is that since the turbo I always kept the lights turned on traction control and no way to remove.... excuse my english, you have not mastered very well'm puerto rico sp2 06-08-2011, 08:08 AM You have check engine light too? When ever i get a check engine light the vsc traction light turns on too Have you tried a code reader and see what codes and or to clear them if any? matrix_XB 06-08-2011, 01:46 PM if the check engine is on but I did not take to see that codes given, any solution to this? sp2 06-08-2011, 06:11 PM I bought a code reader from auto part store or you could order online to see what code or codes your running then you can delete them. So you can turn off lights. You should figure out soon what codes so dont mess up car. ScionFred 06-08-2011, 07:01 PM When the ECU sets an active CEL it also disables TC and VSC. Yes, this is very common when boosting. When I first turbocharged my XB I had the same thing, usually a P0101 (MAF out of range). I eventually solved the CEL issue with a custom intake pipe. The first thing you need to do is get a scan tool so you can read the active and pending CEL codes. Next you can post them with all details of your turbo setup and we may be able to help you sort this out. matrix_XB 06-09-2011, 02:27 AM Thanks.. ScionFred 06-09-2011, 04:20 AM How about some pics? matrix_XB 06-09-2011, 02:16 PM today to my surprise was to mount the Fuel pump and when I Gadolin account of manufactures is smaller than the walbro and the tank is plastic ... any suggestions for this? ScionFred 06-09-2011, 05:12 PM You'll have to modify the plastic pump housing to fit the Walbro. |
