mladen
06-14-2011, 02:52 AM
I'm new to scionlife, (and Scion), so please be nice lol
i've got 2011 tC, does anyone know if 18x9 +38 with 245/40r18 tires will have issues with clearing without rubbing?
The car will be lowered with TRD springs.
Thanks,
gmc_113
06-14-2011, 03:06 AM
why did you make 2 different threads about the same question? keep it on one thread
ibtl
ZeroEyeQueue
06-14-2011, 03:10 AM
I have Work Emotion CR Kai 18 x 8.5" +38 wheels with 245/40 R18's on. The 18 x 9" wheels would've cleared it as well, and will probably look more flush. I test fitted a friend's Volk RE30 18 x 9" wheels with a +35 offset wrapped with a 265/40 R18 tire, and there was no rub at lock while driving, or at least none that I could tell. I have the TRD Springs, as well. Hope that helps.
mladen
06-14-2011, 11:00 PM
^^^ thanks a lot ZeroEyeQueue that really helps!
1stOne
06-15-2011, 12:34 AM
Yes, fitment will be perfect.
I'm at 18x9.5 +45 with a 3mm spacer, so basically +42. Dead nuts flush.
OldBox
06-17-2011, 05:11 PM
I am looking at possibly doing S-Techs with either a 18x9 +30 w/245-40s or 18x9.5 +38 w/255-35s. Trying to figure out if the 255/35 will screw up the computer because of the smaller diameter.
dropzone
06-17-2011, 05:17 PM
^What do you mean by screw up the computer? Only thing I can think of is the mileage on the odometer would be the only thing affected if the overall diameter isn't matched.
OldBox
06-17-2011, 07:32 PM
Don't know if the ECU will get error codes because the RPMs or speedo numbers aren't corresponding with the parameters it has been programmed with.
greenbean24
06-25-2011, 04:18 PM
the computer wont know a difference, for all it knows, its still going the right speed.
OldBox
06-25-2011, 04:48 PM
I guess I will know for sure if I do decide on the different diameter tires.
