Radar wire Re routed ( pics)
Old Mar 18, 2005 | 06:26 AM
pinoyfitness's Avatar
Default Radar wire Re routed ( pics)
I just re-routed the wires because i dont lke how the wires just hang over. I tried to do it through the front vents but couldnt. So i just put it through the face plate.
Check it out
Old Mar 18, 2005 | 06:59 AM
quikgw's Avatar
Nice, what kind of radar is that?
Btw, would the radar work if you put it inside the cubbie hole?
Old Mar 18, 2005 | 07:10 AM
Syr00's Avatar
No i don't think It'll work in the cubby hole because it needs to detect the laser/ radio waves of the cops radar gun when pointed at you.
Old Mar 18, 2005 | 07:11 AM
aznJ's Avatar
i have that same radar, i think...
and i ran the wire the same way, except i hardwired it to the wires for the socket so i still can plug in stuff into that and it's all behind the dash so it looks really clean. the tricky part is figuring out which wire is + or - for the radar power chord and the outlet.
Old Mar 18, 2005 | 08:30 AM
CRxB's Avatar
nice but damn your dash is shinny
Old Mar 18, 2005 | 08:34 AM
TurboMe's Avatar
nice, really needed one tonight cops everywhere on St. Patrick's day and they're anit taking no shiet.
Old Mar 18, 2005 | 10:10 AM
jrv2000's Avatar
just to let you know, the way I was told to install a radar detector was to put it high up on the windshield. I was told that for some reason it can pickup the radar better. Just lettin you know though.
Old Mar 18, 2005 | 02:37 PM
LED-Maniac's Avatar
nice! i like hte clean look, personally I am thinking of hooking up a battery pack to mine but still have to do some research to how long its going to last.
Old Mar 18, 2005 | 02:52 PM
Streeter's Avatar
I've got the same radar detector, in the same place. I wire it through the defrost vents in front (no easy task!) to a power wire near the back of my stereo unit. So no extra wires, and still have the use of both cig lighter sockets. I will take a photo later. There are hard-wire kits that you can get from Best Buy for around $18 I believe.
It's actually (surprisingly) a great radar detector, even though it's not mounted higher on the windshield. Often times I pick up bogeys 3/4 a mile away through tunnels and around curves. (Wondering, "where the heck is he??") If you get a "1" you're safe enough to downshift and slow down before he radars YOU!
Old Mar 18, 2005 | 03:02 PM
motozen's Avatar
yup. Depends if you have a rear facing scanner/360 detection. Here's mine.
https://www.scionlife.com/forums/vie...452&highlight=
Old Mar 18, 2005 | 04:27 PM
scoobyroo2002's Avatar
What are you using on the dash? man it looks shiny HA! i heard it was bad to use stuff on the dash beacuse it can cause it to crack? i personally like the dull look HA!
Old Mar 18, 2005 | 04:31 PM
Fujiz_xb's Avatar
sIcKsCiOnS
looking good.. i need to re route my wire as well...
Old Mar 18, 2005 | 05:12 PM
JasonH's Avatar
Radar detectors are antennas, so the higher they are the better the reception.
Old Mar 18, 2005 | 05:14 PM
bambams247's Avatar
OK SORRY ABOUT THAT!
I will take some pics of my install for you soon hopefully. But I would recomend puting the radar by the A-Pillar or near the center by the rear view mirror it''ll work better. Then you can run the wire through the headliner, a-pillar, and down into the fuse box and ahve it start with your ignition so that you dont ahve to use your cig lighter port. MONEY setup!
Old Mar 18, 2005 | 05:25 PM
slammed's Avatar
I have the exact same rader. Mine is also hardwired but you cant see the wire because I went behind the dash. Mine is also wired to fuse box and I have it secure with 3M tape, not those window thingys.
Old Mar 18, 2005 | 05:33 PM
CDX8's Avatar
sweet....i need to do that
Old Apr 5, 2005 | 04:41 AM
tckurt's Avatar
N.G.S.O.
So if its 360 detection is it ok to put it low? I want it to be installed in the right place don't need any tickets.
Old Apr 5, 2005 | 04:48 AM
sciontc_mich's Avatar
either a little further up the windshield than where it is.. to at least see behind you.. if it's too close to the hood, the metal will not allow the antenna inside the radar detector to receive the signals.. you'll shorten your detection distance.. and could very well get you a ticket.. a cop has NEVER given me a ticket for having my detector 4-5 inches up the windshield.. they usually only go after people with stuff hanging from their rear view mirror..
Old Apr 5, 2005 | 05:14 AM
tC_kevin's Avatar
im gonna get a wireless radar
Old Apr 5, 2005 | 05:27 AM
Krayzie_Los's Avatar
awww, you're not gonna show how many miles you have on your car?
