2004-2006.5 [NCP61]
HELP ASAP Blinking red temperature light
Old Jun 15, 2011 | 07:59 PM
FL21289's Avatar
Exclamation HELP ASAP Blinking red temperature light
So yesterday my wife was driving from work and told me that the Battery light was on, and the temperature light was blinking red.
When she got him i checked it out and the Com. Alt. Water belt had snapped. So that had explained why the Battery light was on and etc....
But today after putting the new belt and car was running fine; she calls me saying that the temperature light was blinking red again but got to work fine and the car was running normal.
I check the coolant level and everything is fine and all. I don't know what else could it be.
Has anyone else had this issue any help will do!
Thanks
Old Jun 15, 2011 | 09:13 PM
Dkfung88's Avatar
time for a new water pump?
Old Jun 15, 2011 | 09:17 PM
eignub's Avatar
bad temp sensor?
Old Jun 15, 2011 | 09:18 PM
ToolishTc's Avatar
water pump is my guess as well. check to see if they pulley on the water pump is frozen, which could be what caused the belt to break as well.
Old Jun 15, 2011 | 11:04 PM
FL21289's Avatar
Ok i will check the water pump then and work from there.
Funny thing is that the light isn't blinking anymore.... not sure whats up.
If not then i also think it might be the sensor.
Thanks guys will update
Old Mar 26, 2015 | 03:53 PM
ascorpiowriter's Avatar
Default Belt issues
I, too, had a problem with my Scion. For months the belt had been screeching, especially in extreme cold weather. One night on the way home the battery, temp, and check engine lights lit suddenly all at the same time on the dash, and I lost heat. Took it ito a mechanic and both belts needed replacing; the serpentine belt had snapped completely due to rot and moisture. Not a surprise since my engine has 104k miles. Mechanic replaced both belts and reset the dash and now everything works fine. Hope this helps.
Old Jan 27, 2017 | 11:00 PM
Lindsay7's Avatar
Default Same problems
I'm having these same problems!! How much did all of that cost approximately!?
Old Jan 31, 2017 | 07:28 PM
jct's Avatar
jct
call a few shops and include that with the dealer. wasn't too bad from the dealer
my06tc
Jun 25, 2015 12:18 AM
NewBox06
Feb 3, 2015 12:36 PM
lexobx
Scion xD Drivetrain & Power
Dec 7, 2014 05:52 PM
Jamster
Nov 20, 2014 07:49 PM
