2004-2006.5 [NCP61]
Disable RKE Key/Alarm system ??
Old Jun 19, 2011 | 02:00 AM
Matt9876's Avatar
Default Disable RKE Key/Alarm system ??
I searched but found nothing.
I need to know what fuse or wire to pull to disable a malfunctioning factory RKE alarm system that is discharging the cars battery over night(s).
A more elegant solution to my problem may be to disable the alarm from automatically activating when the drivers door is key locked.
2006 Scion xA RS3
Found in the Owner's Guide a procedure for "Radar Sensor Mode Off" that might cure the root cause of the problem.
More: Testing the radar sensor off mode to see if this stops the false alarm trips, amp draw readings from the battery suggest it's not a bad alternator or stuck relay. Disconnected horn from the alarm years ago due to the false alarms.
Old Jun 22, 2011 | 02:21 AM
Matt9876's Avatar
Radar Sensor Mode Off worked to fix the false alarms and battery drain, All has been OK since the reprogram sequence.
yhwhdesign
Jun 11, 2021 03:34 PM
Hydryman
Feb 23, 2016 03:35 PM
brett561tc
Sep 15, 2015 06:33 AM
twocamvw
Aug 12, 2015 10:17 PM
Subaru86
Jul 31, 2015 04:33 AM
