Scion xB2 : Dual Color LED Turn Signal Switchback [also xB1]
**xB2 2011 and up now available
* Free shipping within US
The reason is that 2011 model uses different bulb size
Direct link to the ordering page
** Light pattern : White color with parking lights on, changes to amber with turnsignal (amber then off, repeating till turnsignal off) then changes to white
During turnsignal sequence, white color will stay off
- Plug and play style
- Dual color turn signal
- Uses 60 LED (30 hyper white and 30 amber)
- White color for parking lights
- Changes to amber for turn signal
- Less attention from cop and still be able to make the clean look
- Comes as pair (two bulbs]
- 1 Year hassle free warranty
- Compatiable to Scion xB 1st generation (04 - 07)
LED flasher relay you only need one and it will cover all the turn signal.. For the resistor, you need one for each bulb (plus you have to tap the stock wiring....
LED flasher relay is plug and play..
I currently don't have resistor in stock but I do have LED flasher relay in stock..
also interested in the relay as well.... still have not installed mine because I am very skeptical about 1 tapping into my stock harness and 2 the amount of heat that resistor produces....
It's not listed on the site..
You can just paypal me at paypal@LEDmod.com
Then I can send it out to you...
Thanks..
Thanks..
You just pull out the stock relay and plug in the LED flasher and you are good to go...
Thanks..
Thanks..
