Adjusting idle?
Just a quick ? for everyone. I have the ggp motor mount in my xb2, and love it. My only problem is, from 550 to 800 rpm....it vibrates like a mother.
Im curious if anyone knows how to adjust the idle in our cars? My old car was a simple screw that moved the throttle plate and cable to adjust the resting idle. Unfortunately...I don't see anything like that!
Anybody?
Anybody?
I've just spent an hour+ trying to determine if there's a mechanical or electronic adjustment that will modify the ECU handling of the throttle actuator and position sensor from programmed standard, and I'm drawing a complete blank. There's definitely no adjustment at the TB, and reviewing the test procedures for the 2AZ-FE in the Camry, there doesn't appear to be any over-ride (perhaps there's some offset adjustment at the pedal position sensor, but I doubt it). The idle appears to default to a full current cut to the TB actuator resulting in a return spring pulling the throttle plate back to a 6 degree angle. Maybe you can find some Toyota tech that knows some trick, but it's not looking good.
steeze69
May 24, 2021 02:57 AM
SloTC1
Aug 16, 2018 02:45 PM
Darrenohooligan
Sep 26, 2015 07:21 AM
