Mods so far...pics
Old Mar 18, 2005 | 06:32 PM
slammed's Avatar
Default Mods so far...pics
Took some quick shots of my mods so far. Let me know what you think. My car has 1500 miles on it.
Rockford Fosgate hx2 1000watt max
Rockford Fosgate 400s
JVC ar7000
This is the remote bass **** for the amp.
Cobra radar detector, hardwired.
Painted rear emblem. Shaved tC emblem.
Old Mar 18, 2005 | 06:34 PM
SCI_TC_GUY's Avatar
Hey man.....how'd you mount the bass **** behind the dummy panel.....i never thought of that....might have to steal the idea...
BTW....i had one of those subs (dual 2 ohm) in a ported box i designed and built with a Sony 1000x1 runnin 1 ohm mono and hit a 150.4dB on the dash of an eclipse 1st gen......very badass......
Old Mar 18, 2005 | 06:38 PM
Fujiz_xb's Avatar
sIcKsCiOnS
bass *** looks great. i need one for my alpine mrd-m1000 amp
Old Mar 18, 2005 | 06:39 PM
slammed's Avatar
I had to take the bass remote apart to get it down to the chip and just the ****. I drilled a hole through the plastic piece and put the **** through, It took some finesse but it worked out.
Old Mar 18, 2005 | 06:44 PM
DJ_X_Trodinaire's Avatar
nice
now make a trim panel so you can cover the exposed wires
Old Mar 18, 2005 | 06:49 PM
slammed's Avatar
exposed wires? everything is hidden in the wheel well. The only wires you can see are the 2 coming out of the sub and you cant even see those because the sub box hides them.
Old Mar 18, 2005 | 08:05 PM
SCI_TC_GUY's Avatar
i think he's talking about in the amp box.....also might consider a fan in there to take care of a little heat......or stilts for your amp...
Old Mar 19, 2005 | 12:35 AM
sco1500's Avatar
Good mods, slammed. I have the same head unit. I like the features it has.
Old Mar 19, 2005 | 02:45 AM
nchyflyer's Avatar
how'd you hide your radar detector wires? WHere'd you hook them to? Info please!
Old Mar 19, 2005 | 05:56 PM
slammed's Avatar
the power wire is in the gauge fuse in the fuse box under the steering wheel. I grounded it on a nut under the dash. The wire was fed up the left sideand then pushed down along the window and the dash.
Old Mar 19, 2005 | 06:04 PM
bambams247's Avatar
Looks good an all but dude PLEASE clean up that amp wiring! I mean come on, you can do better than taht if u wired it all up yourself! Make it a lil mo clean:
Old Mar 19, 2005 | 07:28 PM
slammed's Avatar
ok ok, ill clean it up. I didnt really care because no one is ever going to look down there. Ill post updated pics soon.
Old Mar 19, 2005 | 07:31 PM
slammed's Avatar
Hey bam are your wires all coming from the top of the unit? Any on the sides? I had to cut out the area with the warning sticker so I had room for the wires.
Old Mar 19, 2005 | 08:44 PM
bambams247's Avatar
mine are all comeing from the back under the amp then and into it, hidden uner the cover plate and the amp is raised about an inch with spacer for wires to run and airflow as well
Old Mar 19, 2005 | 08:56 PM
pinoyfitness's Avatar
looks like you nick a paint out when you took that rear emblem off... I like how you hardwired your radar... how did you do it?
Old Mar 21, 2005 | 01:50 AM
slammed's Avatar
Yes i did take a nick out. I was wondering if anyone would notice. I used a smal screwdriver wrapped in micro fiber but it stil nicked it.
Old Mar 21, 2005 | 02:20 AM
hamadeh's Avatar
hey what did you color the emblem what color was it and how did you do it i think i want to do that to mine i like it, how you do it... take it off and paint it and put it back how? and what color is your car, and can you put a pic of your car from the rear furthur away.
Old Mar 22, 2005 | 02:25 AM
hamadeh's Avatar
Old Mar 22, 2005 | 02:35 AM
TurboMe's Avatar
ummm that was his original emblem, it took it off and painted it and put it back on.
Old Mar 22, 2005 | 03:01 AM
WarrenSteve's Avatar
which deck install kit did you use? work ok??
