wheel spacers
Old Jun 29, 2011 | 08:32 PM
colinantherus's Avatar
Default wheel spacers
what size wheel spacers would i need to be flush after i order coils?
Old Jun 29, 2011 | 08:37 PM
Hayseed's Avatar
Umm what offset wheels... What size wheels...etc
Old Jun 29, 2011 | 08:39 PM
stock wheels and tires. just black painted stockies
Old Jun 29, 2011 | 08:45 PM
Hayseed's Avatar
Here's your problem. not trying to be a jerk, just trying to help. The reason us fitment guys run stretch tires is so we can actually make turns with wide wheels on low cars. With stock tires, you're gonna run into the huge issue of turning, depending on how low you go. You're gonna end up with a buckled fender. So to answer your question in a realistic sense, no you shouldnt try to get your stock wheels flush. Running 10mm spacers max would be fine.
To answer your question though, at least 25mm. I believe the stockies are et47?
Old Jun 29, 2011 | 08:49 PM
so you think i should just try and go for a little less than "tucked"
Old Jun 29, 2011 | 08:51 PM
Hayseed's Avatar
Save your money. 5mm slip ons at most. Any bigger and you have to cut your wheel studs. Not worth it IMO.
Old Jun 29, 2011 | 09:02 PM
i think im just gonna lower it and not worry about the spacing of the wheels. it will look better either way
Old Jun 29, 2011 | 09:05 PM
Hayseed's Avatar
Much simpler. Cutting studs aint fun at all. I have to for my setup, but oh wells
Old Jun 29, 2011 | 09:07 PM
i agree. it would save me money and ill still get looks :D
Old Jun 30, 2011 | 12:51 AM
jeremydoc's Avatar
i completely agree with everything hayseed said. stretched tires are a mush for a low car and wide wheels. or else nothing will fit. stock setup will only get you into problems. and i thought stock offset was 45
Old Jun 30, 2011 | 01:01 AM
Hayseed's Avatar
Eh I think you're right. et45 it is.
Sent from somewhere using Something.
Old Jun 30, 2011 | 05:35 AM
Eziekel's Avatar
you can run a 15mm or 25mm spacer with stock wheels if you wanted and not cut your studs. your stock wheels have indentations on the back where your stock studs will fit into if you run a wheel adapter spacer.
Old Jun 30, 2011 | 05:40 AM
Hayseed's Avatar
but there goes your turning ability and fenders
Old Jul 1, 2011 | 12:20 AM
Mos_Def's Avatar
i believe you need 20mm spacers up front and 25mm spacers in the rear to be flush with OEM wheels. as long as youre not slammed, you should be ok running the OEM tires. if youre running that thick of spacers, there is no need to cut your studs. i highly doubt your turnin ability will be affected since OEM wheels are only 7in wide.
Old Jul 1, 2011 | 12:36 AM
i think im just gonna wait to be flush till i get deep dish rims :D
terrye
Jan 25, 2015 05:31 AM
CAtC12
Dec 23, 2014 04:44 PM
avus
14
Aug 6, 2004 09:27 PM
scionara
38
Feb 25, 2004 04:52 AM
Hardhitten
Nov 2, 2003 08:29 PM
