Please Help-Replaced Stereo, now Pass. window wont work
Old Jul 1, 2011 | 01:29 AM
Souphead's Avatar
Default Please Help-Replaced Stereo, now Pass. window wont work
At least not from the driver side controls--It DOES work from the passenger side. HELP
Stereo works fine, and as far as I can tell this is the only problem.
What could have happened that would cause the passenger window to not respond to the driver side control?
Yes the window lock is off ;)
Old Jul 1, 2011 | 02:17 AM
07ohiotc's Avatar
I presume when you replaced the stereo, you disconnected the battery? If that's the case all you have to do is simply reset them. Lower the window down half way with the power turned to "ON". Then fully put the windows down and continue to hold the window button for another 2 seconds.
You might want to look it up exactly how to do it, but I'm pretty sure that's what you have to do.
Old Jul 1, 2011 | 02:30 AM
Souphead's Avatar
Yes the I disconnected the Negative terminal of the battery. Its good news if thats all it is.
I've never heard of resetting the windows. I'll look it up
Thanks!
Old Jul 1, 2011 | 02:32 AM
07ohiotc's Avatar
Yeah you have to reset the power windows. It's something like that
I remember having to do it when I installed my system.
No problem, hope it works!
Old Jul 1, 2011 | 09:11 AM
Eziekel's Avatar
yeah, you just have to reprogram it. but you roll ur window all the way down first having ur key turned to "on". then you roll it up half way, then let go. then roll it up all the way and hold for more than 2 seconds. then all your controls will work.
you'll also have to reprogram the sunroof as well, same procedure.
wiltonhall
Jun 23, 2025 10:09 PM
SuperXero
Scion tC 1G ICE & Interior
Feb 23, 2020 08:17 AM
herwig
Mar 23, 2015 04:19 AM
reagan9000
Jan 28, 2015 06:20 PM
pier0723
Dec 3, 2014 03:38 PM
