View Full Version : Removing taillights
Romanova
03-20-2005, 01:56 AM
Where are the 10mm bolts that secure the taillight to the body? What is the best tool to remove them with... 10mm wrench or 10mm swivel socket?
I removed the access panel and felt around in there but only felt two smooth posts... didn't feel like they had nuts on them.
Thanks.
Kairoh
03-20-2005, 02:10 AM
They're in there. Get a flash light and look in it at an angle looking back at the lights. What you will need is a socket with like a 3 inch extension on it. Not that hard once you find the bolts. Good luck.
stick_1NZ
03-20-2005, 02:23 AM
What are you trying to do with your tails???? Just wondering.
Romanova
03-20-2005, 02:39 AM
Paint them with red stained glass paint for the 'red-out ' look. The clear doesn't look good IMO on a white car, and all the aftermarket tail lights are so horrible looking I can't even consider getting a set.
stick_1NZ
03-20-2005, 02:43 AM
are you going to paint inside the cover or outside....if it's outside you can just pop the cover out from the housing....use a flathead screw driver but be careful not to crack the plastic cover. i did it. check my avatar.
Soon2BxB
03-20-2005, 05:49 AM
first off ive removed the covers a few times.. they dont just POP off with a screw driver... doing that is asking for broken tails ... the plastic lense is fragile and will def CRACK easily
and second
its MUCH EASIER to take out the 2 bolts and just do it that way
if u feel inside - the 2 posts you feel on the taillight assembly are where the nuts are secured... u cant miss em
Scion05BOPxB
03-20-2005, 04:25 PM
I'm planning to mod my tails too. I think the stock tails are the ugliest part of a stock xB.
03-21-2005, 04:25 AM
just removed my tailights as well took me about 10 min on each side
twidelde
03-21-2005, 05:48 AM
All I know is that the top nut is in a very difficult place to remove it. I found the wrench was the easiest to get it off.
