5W-20 conventional vs. 0W-20
Old Jul 28, 2011 | 12:40 AM
Toastercar's Avatar
Default 5W-20 conventional vs. 0W-20
Yesterday I went to a quick lube place to have my 2011 Scion xB inspected. I'd had the first two oil changes done at the dealer and they put in 5W-20. The third was done at this quick lube place, again with 5W-20 used. After the inspection this place noted that the car was soon due for another oil change and handed me a printout which included the following (highlighted in yellow): "0W-20 is the best choice for good fuel economy and starting in cold weather. If 0W-20 is not available, 5W-20 may be used. However, it must be replaced with 0W-20 at the next oil change." The techs stated that this was from Toyota and that not using the 0W-20 oil could jeopardize my warranty. My manual does recommend using the lighter oil, but lists the 5W-20 as suitable as well. There is nothing that I can find that has the 0W-20 as a requirement. My dealer was not reacheable today due to a power outage but I plan to call them. Has anyone else encountered this? Has Toyota changed its oil viscosity requirement?
Old Jul 28, 2011 | 01:00 AM
SamCarroll's Avatar
0W-20 is just fine to use in 08+ xBs Toyotas spec sheet does say for cold starting and better fuel economy.
Old Jul 28, 2011 | 01:08 AM
Toastercar's Avatar
I have no problem with the 0W-20. I just think that this place may be hyping it as a requirement to get a bit more dough from the customer.
Old Jul 28, 2011 | 02:12 AM
SamCarroll's Avatar
Its not a requirement. Just by choice.
Old Jul 28, 2011 | 02:38 AM
Rockztar's Avatar
i don't think there is a difference in price, or atleast every time i get my oil from autozone or walmart they cost the same but 0w-20 its a little bit hard to find
Old Jul 28, 2011 | 03:29 AM
SamCarroll's Avatar
Old Jul 28, 2011 | 03:50 AM
Rockztar's Avatar
so what? i do my own oil changes....but thats not the point; the point is that 0w-20 and 5w-20 are the same price
Old Jul 28, 2011 | 11:45 AM
Roller_Toaster's Avatar
Walmart is the only place I know that carries the 5qt jugs of 0w-20 for around $20-25.
Everywhere I have checked else seems to only sell the single quarts for $6.99.
Old Jul 28, 2011 | 12:33 PM
Ometta's Avatar
I know in my tC manual and my oil cap say 0W-20 / 5W-20. Dealership puts in 5W-20. Doesn't matter what you use. Either of those will be fine. Don't worry about your warranty on the engine cause it will run 200k+ miles with no problems.
Old Jul 28, 2011 | 04:33 PM
jnaval's Avatar
The oil cap says 0W20/5W20, that place is just using scare tactics to make you buy 0W since it's generally more expensive than 5W.
Old Jul 28, 2011 | 04:53 PM
ScionFred's Avatar
Toyota recommends 5W30 if you have the TRD supercharger. I wouldn't dream of running 0w20 or 5w20 in a boosted engine or a N/A engine seeing any race duty.
Old Jul 28, 2011 | 09:30 PM
SamCarroll's Avatar
Id honestly only consider 0w if you have a long commute, colder climates and take your car on trips very frequently. Otherwise 5w is just fine.
Old Jul 29, 2011 | 12:27 AM
divisii's Avatar
When I used 0w at a sustained rpm on a 2day road trip, I burnt about a quart of oil. running at 3500+ rpm all day, dealer said it's not unusual/my car was within specs. Either oil shouldn't be a warranty issue.
Old Jul 29, 2011 | 01:00 AM
^weird. I run 0w-20 and drive 75+ highway miles a day. Never noticed the dipstick looking low at all.
Old Aug 1, 2011 | 10:17 PM
drewsxb808's Avatar
i been using 0w-20 for about 3 years now and it has worked great. noticed a small bump in fuel economy, about 2 mpg on average, and i never had any issues with it at all. and it definitely cost ,ore then 5w-20 at least here in hawaii it does. i use mobile 1 and its usually $7 a quart unless its on sale.
theres benefits to it but its definitely not required.
Old Aug 1, 2011 | 11:41 PM
That's why you buy the 5 quart jug. Its the same price as the 5w at walmart, or anywhere that isn't an automotive specific parts store.
Old Aug 2, 2011 | 12:44 AM
jnaval's Avatar
Those jugs are rare in my 'hood.
Old Aug 2, 2011 | 01:23 AM
My local walmart is literally the only place I can get them in my town.
Old Aug 2, 2011 | 02:06 AM
AAG's Avatar
AAG
DeepSouth Scions
Im using 5w-20 because Mobil 1 Extended Performance doesnt come in 0w-20. Running it 10k miles with a mobil 1 filter.
If you're running your oil 5k miles or less, 5w-20 dino is fine. The mpg increase from 5w to 0w is BS btw, if it does increase your mpg, it would be minimal at best.
Old Aug 2, 2011 | 03:00 AM
Eh, I guess so. I can tell a difference and I drive around 75 miles a day, so I use it.
