Broken Caliper Bolt
Old Aug 2, 2011 | 11:26 AM
game-boy's Avatar
Default Broken Caliper Bolt
Post archived
Old Aug 2, 2011 | 11:47 AM
Scionwest's Avatar
Who replaced your caliper?
Old Aug 2, 2011 | 01:01 PM
SuperXero's Avatar
yeah the one of the bolts on my caliper broke too, but it wasnt the one you normally remove to change the brake pads. i emailed toyota of the issue but no responce
Old Aug 7, 2011 | 04:21 AM
dmpsk8's Avatar
I've never heard of replacing these during pad changes. If it's really necessary, that's good to know.
I've got 65K miles on mine and the calipers have been disassembled/reassembled twice.
Old Aug 13, 2011 | 08:21 PM
frogbox's Avatar
A good set of pads come with the new bolts , you use the old one to pull the rotors off .And you should always change out the hardware when doing the brakes , saves you from this problem.
Old Aug 13, 2011 | 08:45 PM
egobuster1's Avatar
this exact thing happened not to long ago on my tC
i was driving downy he interstate doing about 70mph and when i went to slow down i hit my brakes and the top caliper bolt had broken and when i braked the caliper must of fell forward into my wheel and got jammed so it shattered the inside of my rim and caused me to lose most of my braking system.
give you a little bit of a idea of how it broke my wheel
Old Aug 13, 2011 | 10:48 PM
KiKaZ-tC's Avatar
Those 14 mm bolts are only suppose to be torqued to 25 ft/lbs.
I've changed my pads more then 4 times without ever replacing any bolts.
Failure on torqueing the bolt down to spec.
yupinmytC
22
Jul 27, 2024 07:08 PM
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
rvascion
Nov 12, 2020 03:23 AM
Sgtfluffy16
Sep 30, 2015 01:42 PM
crimson_sinn
Sep 25, 2015 09:41 PM
