Spacer questions
Old Aug 9, 2011 | 11:43 PM
vancouverray's Avatar
Default Spacer questions
I'll be using 10 mm spacers on the back. Are spacers a direct bolt on ? The shop that is doing the work says they have to punch out the wheel studs or something like that . Guess I will be using ichiba 10 mm from e bay .
Old Aug 9, 2011 | 11:58 PM
xseveredveganx's Avatar
Utah Scions
It depends on the spacers... Most 10mm are slip ons that need to be used in conjunction with longer wheel studs. Hence why the OEM studs need to be punched out. Nothing a quick pop of a hammer won't handle. Easy peezy.
You can use other ones than Ichiba. Just make sure they're hubcentric.
Old Aug 10, 2011 | 01:04 AM
tc913's Avatar
you can go with bolt on spacers that have studs in them or the ones with extended studs that replace your stock studs. if you go with the bolt on spacers you want to see if your rims have enough space in the rear to clear your stock studs sticking out of the spacer. if there isn't space....then you gotta cut your stock studs.
Old Aug 10, 2011 | 01:18 AM
Thanks for the info .Now I'am all set , should have it all done next week.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
