Will I pass CA smog check with these mods?
Old Aug 15, 2011 | 06:41 PM
gqdabien's Avatar
Default Will I pass CA smog check with these mods?
I have an 05 TC Auto with the following mods:
K&N air filter
TRD Supercharger w/ 9.5lb pulley
Tusdo catback exhaust
I am hoping i will pass since i do not have aftermarket header or downpipe, and still retaining the stock air box. Is this true?
Thanks so much to whoever responds!
Old Aug 15, 2011 | 06:55 PM
syberspyder's Avatar
You'd pass the OBD test, I'm not sure if this would pass the sniffer test, since it deletes one of the cats. It's been so long since I've gotten a car smogged(new car 5 year no smog rule ), so I don't know if they would do a visual inspection under the car.
Old Aug 15, 2011 | 07:50 PM
I was curious(live in CA too), and bored
So I found this:http://www.smogcheck.ca.gov/80_BARRe...08-09%20V3.pdf
Basically, your exhaust will fail visual inspection. Also, fyi and others 6 years and newer are exempt.
Old Aug 15, 2011 | 08:44 PM
gqdabien's Avatar
Thanks so much syberspyder for the info, i'll def give this a read-through. I got pulled over 2 years ago for loud exhaust so i took it to BAR station to get tested, and passed that. Since then my setup has been about the same so i'm hoping its the same test.
My 05 just crossed the 5 year mark so i need to get it smogged now.
Old Aug 15, 2011 | 11:54 PM
Reactor's Avatar
The EO# actually specifies Pulley diameter.: http://arb.ca.gov/msprog/aftermkt/de...o/D-425-18.pdf
Old Aug 16, 2011 | 01:08 AM
/\ Good find. That's Cali for ya.
Has anybody with a modified SC in CA had their car smogged and not gone over with a microscope. I'm wondering if this is as thoroughly tested as suggested.
Old Aug 17, 2011 | 05:26 PM
Syldrin's Avatar
there are crooked smog shops everywhere man just do a little hunting if you don't want to take it off. but keep in mind you're going to pay extra.
Old Aug 25, 2011 | 01:53 AM
gqdabien's Avatar
To bring back this thread one more time, the smog guy i went to needed me to show that the TRD Supercharger part number was indeed smog exempt.
I did have paperwork from CARB for the supercharger (this one: http://arb.ca.gov/msprog/aftermkt/de...o/D-425-27.pdf ).
But the above pdf doesn't list part number which is weird.. anybody encounter this same problem? I have no clue where my CARB sticker went and TRD/Toyota won't issue me another one!
Thanks so much everybody!
Old Aug 30, 2011 | 09:09 PM
SoulXquisite's Avatar
-u need the correct pulley, the stock BPV (if your running the bosch 110bpv), and the stock S/c air box with the hydrocarbon trap filter still intact. probably would need that stock long mid pipe under your car.
-im in the same boat, probably do smog in a year or 2, im running 110 bosh bpv, 9.5 nst pulley, TRD modified cai, soon to be running megan- midpipe
Old Sep 4, 2011 | 10:23 PM
gqdabien's Avatar
Just got the smog done, and barely passed. I was able to get the carb sticker for my s/c by calling TRD directly. So I guess 9.5 psi pulley with s/C is still passable if your cats are still good.
Old Jun 22, 2013 | 05:47 PM
Did a search, but didn't find an exact answer so I figured I'd bump this thread.
I need to smog my car soon and I was wondering if a wideband O2 sensor on an aftermarket s-pipe would fail a visual inspection(CARB)? The PDF file that I linked to earlier in this thread mentions 'modifying sensors', but I don't know if this includes adding an O2 bung.
I am in the middle of putting stock supercharger parts back on my car(intake/pulley), and would like to avoid changing the s-pipe if I don't have to. Anyone in Cali recently smog their car notice if they visually check the s-pipe O2 sensor?
Strader
25
Jul 22, 2004 09:27 PM
Carson_Scion_TRD_Parts
Dec 30, 2003 09:29 AM
vho
Dec 9, 2003 11:44 PM
Dec 5, 2003 07:14 PM
Docsnuff
9
Nov 23, 2003 09:50 PM
