Radio, lighter, side mirrors dead on 2005 xB
Old Aug 16, 2011 | 03:08 PM
kragg's Avatar
Default Radio, lighter, side mirrors dead on 2005 xB
Hi all,
Hopefully I am posting this in into the correct forum. I have a 2005 xB and the other day my radio went dead. Then I checked and my cig lighter and side mirrors were also out.
I did some research and checked the 15 ACC fuse on my inside fuse box. It was blown so I used the spare 15 that was in my fuse box under the hood.
However, everything is still out....
Does anyone know if there is a second fuse I might need to replace to get everything working again? Someone mentioned to check the dome light, and that I might need to replace the DOME fuse under the hood as well?
Any help would be appreciated since I'd rather not have to check 20 fuses to see if all of them are blown or not.
Thanks.
Old Aug 18, 2011 | 02:24 AM
05sciko's Avatar
my dome light fuse went out and did the same thing. its the one under the hood. it happened when i replaced my radio
Old Aug 18, 2011 | 01:27 PM
kragg's Avatar
Thanks 05. I will check it out. My dome light actually works, so I didn't think to check that fuse. I will take a look though.
Old Aug 20, 2011 | 12:51 PM
Zman's Avatar
ACC fuse, 15A I believe.
Old Aug 20, 2011 | 02:44 PM
SentraSE-R's Avatar
You probably have a short in the ACC circuit, and blew the same fuse again. Get a multimeter and trace the system until you find the short. Do NOT put a higher amp fuse in the fuse block, or you run the risk of melting wires and starting a fire.
Old Aug 20, 2011 | 08:48 PM
Zman's Avatar
Well that's a bit tougher!
Maybe a body panel is pinching a wire somewhere (if he took something apart, etc).
Old Feb 11, 2015 | 01:17 AM
FlyLow's Avatar
Renewing this thread: 2006 xB. I replaced the 15 A ACC fuse (with the 15A Dome fuse from under the hood because I had already scavenged the 15A spare for another project), and the Cig lighter works and the mirrors adjust, but still no factory radio. Blank display. Suggestions? (Fuse blew originally from a shorted USB charger/converter in the Cig hole.)
Thanks!
Old Feb 11, 2015 | 02:25 AM
FlyLow's Avatar
OK! Thanks for your patience: Replaced the 15A Dome fuse under the hood and all's well. The Dome fuse also controls (deletes) the Trip A and Trip B record.
So, now we know that the Radio needs both the ACC and the Dome fuses to work.
Old Jul 11, 2015 | 11:18 PM
x2x3's Avatar
That can be tuff; where is the repair manual.?
Old Jul 29, 2015 | 12:51 PM
lcw's Avatar
lcw
Default fuse box.
Hi. My radio died, I bought the fuses, but don't know where the fuse box is. Dealer was no help. Help?
mischadoll
Mar 9, 2015 05:48 AM
mischman
Jan 14, 2015 06:07 PM
minter66
Dec 15, 2014 01:45 PM
Male_Nurse
13
Mar 10, 2008 02:51 AM
