Got a problem need help quick
Old Aug 25, 2011 | 01:35 AM
SokaltC's Avatar
Default Got a problem need help quick
So I was going through my tc doing regular stuff getting ready to turbo it and I noticed oil on the thread of my spark plugs. What is causing this tc is bone stock right now.
Old Aug 25, 2011 | 01:41 AM
SokaltC's Avatar
Please dont tell me a head gasket, car has 84xxx
Old Aug 25, 2011 | 02:18 AM
BeloZero's Avatar
It's not the head gasket, the only thing I know will do that is the valve cover gasket. It's an easy fix. If it was the head gasket or the piston rings, it would be smoking and probably see more oil. Goodluck, hopefully you can get it fixed
Old Aug 25, 2011 | 02:23 AM
BeloZero's Avatar
If you do change the VC gasket, make sure you get the torque specs from scion and use a star pattern to tighten the bolts back down. If you mess that up, you'll end up doing it all over again.
Old Aug 26, 2011 | 12:13 PM
bikerdude1550's Avatar
Could it be antiseize? Our cars have an all aluminum head
Old Aug 26, 2011 | 12:16 PM
mrexotica's Avatar
Nope
Old Aug 26, 2011 | 02:31 PM
SokaltC's Avatar
What do you mean antisieze? And I have another problem it sounds like really loud gear whine at 2000-3000 rpms then it goes away. Any ideas?
Old Aug 26, 2011 | 04:12 PM
thetruthtruth's Avatar
if its engine oil its most likely coming from the manifold gasket, check it to make sure its line up properly. I accidently had a piece of my gasket not tucked into its grove, well i drove like that for 5 min before the smoke started pluming. to say the least my whole engine bay was covered in oil lol
gear wind noise can be rasp coming from the exhaust, prolly needs new resonator.
Old Aug 26, 2011 | 06:17 PM
mrexotica's Avatar
How could gear whine be rasp from the resonator?
Have you ever changed your trans fluid?
Old Aug 26, 2011 | 06:19 PM
mrexotica's Avatar
Also, if you turbo an 84k mi car without making sure the Drivetrain is in perfect shape, expect problems.
Old Aug 27, 2011 | 01:54 AM
SokaltC's Avatar
Thats why im going through and checking everything, I dont know if the transfluid has been changed i picked the car up at 79000 I have not personally dont it.
Old Aug 27, 2011 | 01:55 AM
SokaltC's Avatar
resonator in perfect shape, car came from florida so zero rust on any part of the car and the exhaust is solid went through and checked it.
Old Aug 27, 2011 | 03:36 AM
mrexotica's Avatar
Now would be a good time to replace the timing chain & check compression.
Old Aug 27, 2011 | 03:49 AM
SokaltC's Avatar
And if the resonator was bad wouldn't I hear it at any rpm?
Old Aug 27, 2011 | 12:02 PM
PeArLwHiTe07tC's Avatar
the timing chain doesnt need to be changed at all. it doesnt have a service interval. i have never seen one go or stretch, im not saying that itll never happen but its not likely.
Old Aug 27, 2011 | 02:11 PM
SokaltC's Avatar
I didn't think the timing chain needed to be changed either that's why I kinda ignored that statement.
Old Aug 28, 2011 | 01:01 AM
BeloZero's Avatar
have you looked at the friggin VC gasket yet. im willing to bet thats your problem
Old Aug 28, 2011 | 03:49 AM
SokaltC's Avatar
Yeah it didn't look like it was that bad I am putting it back together tomorrow
Old Aug 28, 2011 | 08:15 AM
BeloZero's Avatar
did you get a new one? i dont think you can reuse that gasket
Old Aug 28, 2011 | 12:59 PM
SokaltC's Avatar
Yes bought a new gasket would never reuse an old one.
