Engine just shut off on highway and now won't start
Old Aug 27, 2011 | 01:18 AM
dEEYOUNEE1's Avatar
Default Engine just shut off on highway and now won't start
Posting from iPhone guys. Will elaborate later. My car randomly shut off while driving on the highway and now I can't get it restarted. What can it be?
Old Aug 27, 2011 | 01:22 AM
dEEYOUNEE1's Avatar
I should add lights, power steering and stereo work
Old Aug 27, 2011 | 04:23 AM
r2d2michael's Avatar
no codes? what year do you have? my 2009 did this and i got no codes. it would start after about 30 min of sitting.......on the side of the road......
Old Aug 27, 2011 | 04:39 AM
Dam262a's Avatar
check the terminals, if that seems fine she if you can get a jump your battery could be slightly alive but still allow you to use the smaller electronics
Old Aug 27, 2011 | 04:54 AM
dEEYOUNEE1's Avatar
08 no codes, boosted but no dice.
Old Aug 27, 2011 | 06:05 AM
well if its a 08 does the TSB on the wiering harness have anything to do with it?
Old Aug 27, 2011 | 06:21 AM
dEEYOUNEE1's Avatar
reference?
Old Aug 27, 2011 | 06:26 AM
http://www.aboutautomobile.com/TSB/2008/Scion/xB
look at these. the one about the wireing harness i think is something else
Old Aug 27, 2011 | 08:21 AM
ScionFred's Avatar
Is there gas in the tank?
Please elaborate.
Old Aug 27, 2011 | 04:33 PM
Please elaborate.
so that was E means.... lol
Old Aug 27, 2011 | 09:46 PM
TrevorS's Avatar
You say it "randomly shuts off", so I gather you've been experiencing this behavior for a little while? I gather you don't get a check engine lamp on the display? How long have you been seeing this and has it been gradually getting worse? You say you're boosted, does the time frame of that correspond at all with when you started seeing this behavior -- was it before or after this behavior first appeared?
Old Aug 27, 2011 | 10:45 PM
dEEYOUNEE1's Avatar
that was the first time it happened and when I say boosted I mean with jumper cables haha. I found a dead fuel ignition fuse and now everything is kosher. Thanks guys
Old Aug 27, 2011 | 11:10 PM
TrevorS's Avatar
Happy to learn you solved the problem! Around here, "boosted" means F/I (forced injection), and so brings in a number of factors that aren't a concern for N/A drivers (natural aspiration). Happy driving !
Old Jul 15, 2014 | 03:45 AM
lilfx's Avatar
Default I am having same issue
I can be driving at any speed and motor just shuts off.. even leaving a light and have to turn it over 3-4 times... when I try to restart RPM's go up like normal and then just drop off to dead.. I have taken in into dealer 3 times and it will not throw a code... when motor dies off everything still works gauges, stereo, lights, fog lamps, etc... I am getting frustrated about this.. all fuses are good and dealer says everything is working properly.... anyone else having any other problems.... not boosted, have exeady stage one, and light weight flywheel, has been running fine for a year with these and now have problems. .. please help
Old Aug 4, 2014 | 03:43 AM
Linand3's Avatar
Default 2008 Scion XB engine shut off!
My 2008 XB has been doing the same thing! It's happened on the freeway & city streets! Today I almost got hit by a car from behind! It was so scary!! Calling Toyota dealer in the morning! The VCS , Traction, and check engine lights come on sometimes when it happens. Not all the time though! Approximately 90,000 miles.
Old Aug 11, 2014 | 07:19 AM
lilfx's Avatar
I had the lights come on once... but they keep trying to tell me nothing is wrong... on the 18-20th I will be taking the service manager out for a drive and show him what's going on... also when mine just shuts off it has to be turned over 4-5 times for the engine to stay running... the rpms go up but just drop off I have a video of it but don't know if or how I can post it up on here... i have about 133,000 miles on it and it just started 3 months ago....
Old Aug 17, 2014 | 02:06 PM
AAG's Avatar
AAG
DeepSouth Scions
My 2008 XB has been doing the same thing! The VCS , Traction, and check engine lights come on sometimes when it happens. Not all the time though! Approximately 90,000 miles.
Mine did this around 20k miles (cluster lit up like a Christmas tree) and the wire harness was replaced. Early build 2008 .
Old Oct 8, 2016 | 11:31 PM
typeflex's Avatar
THIS WAS THE EXACT SAME PROBLEM THAT HAPPENED TO ME.
Got stranded today at 6 in the morning 9 hours away from home, xb just shut off. I said damnit, this is it, I'm f'd.
Did a quick search, came up with this query, checked the fuse, sure enough.
THANK YOU OP, you're a life saver!
Old Jun 13, 2023 | 01:49 AM
abbylink_32's Avatar
Default Hi! I have the same issue a troubling to trouble shoot some on my own!
something is happening to me an I’m curious in more in-depth to you situation you had so I can maybe try an figure mine out.
Jordly221
Feb 13, 2019 05:29 PM
Monkey343
Scion xD Suspension & Handling
Nov 10, 2016 02:07 PM
cid_mcdp
Jan 5, 2015 02:45 PM
eric_m
79
Mar 17, 2013 12:21 AM
scionspecialistvegas
Dec 15, 2003 11:21 AM
