stock sub and power lock help!!!
Old Aug 29, 2011 | 03:34 PM
jeremydoc's Avatar
Default stock sub and power lock help!!!
so i need some help guys. so my stock sub hasnt been working in a while, but i just disregarded it since i had aftermarket subs and amp. but now i removed my aftermarket cuz of the space issue, and now it bugs me that i dont have any bass at all. so i figured it was a fuse issue. i checked all the fuses under the hood, everything is perfect. i checked all the fuses under the dash, and everything is perfect. i checked the manual for which fuse to check for the audio stuff, and those were fine also. so i pretty much gave up and i was gonna take it to the dealership since im still under warranty.
so now ANOTHER problem comes up. so i put all the fuses back where i removed them from. i was leaving my car and i clicked the lock button on my key fob. i noticed i didnt hear my car lock(as i usually do since its kinda loud). i noticed my car doesnt lock anymore when i hit the lock button. i rechecked all my fuses and their placement, and everything is fine where they are. the thing is, when i hit the unlock button, the lights turn on and off twice like normal but stays locked(if i locked in manually). if i hit lock while the car is unlocked, it does nothing. not even lights turn on.
....then i remembered, when i removed my battery a couple times before, i would have to do that window reset thing for it to work again. im thinking that i might have to do that with the power locks also. i just dont know how to do it.
if you have any info on either the stock sub/amp and/or the power lock, any help is appreciated.
Old Aug 29, 2011 | 05:52 PM
twitchion's Avatar
I think if you have an aftermarket head unit the factory sub won't turn on because of the turn on lead is different. i could never figure it out.
your locks are weird. i undo my battery alot and i've never had that problem
Old Aug 29, 2011 | 06:47 PM
RR08tC's Avatar
I have an aftermarket head unit and my subs fine. You might have just shorted the amp out
Old Aug 29, 2011 | 07:29 PM
jeremydoc's Avatar
i have the stock headunit. when i had my aftermarket sub/amp installed, they spliced the line-out-converter into the stock sub. both were working at one point. i dont know what happened, just stopped working.
Old Aug 29, 2011 | 08:26 PM
jeremydoc's Avatar
i just realized, my sunroof doesnt open either. and since i cant unlock the powerlocks, i cant open the trunk
Old Aug 30, 2011 | 12:20 AM
jeremydoc's Avatar
So I think I might have just put the fuses in the wrong slots. If someone could be nice enough to snap a pic of te fuse box under the driverside dash for me so I can see the placement. I'll send you some free stickers.
Old Aug 30, 2011 | 05:43 AM
jeremydoc's Avatar
looks like no one is getting stickers. haha. i went to wild1413's hose just now and compared our fuses(since mine werent blown). i guess i accidentally put three fuses in the wrong slot. HAHAHHAHA. what a dumbass. lmao! problem solved.
SloTC1
Apr 2, 2015 07:11 PM
mischman
Jan 14, 2015 06:07 PM
toyotaisme
Jan 10, 2015 10:24 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
kagero79
Jul 10, 2008 03:29 AM
