View Full Version : ARP Extended Wheel Studs
B2FiNiTY
03-22-2005, 04:52 AM
Is anyone running extended wheel studs that are much longer than stock? I've seen the h&r ones that come with spacers and that is not long enough for my tastes.
Honda/Acura has the same 12x1.5 pattern but is it the same size? Will those work on the xB?
Thanks.
ScionxR
03-22-2005, 05:10 AM
how can you tell what size to push them out w/o rubbing anywhere? i want to push mine out about 9 inches or so but dont want to rub anywhere and ruin my wheel well
JDM_Junkyard
03-22-2005, 05:12 AM
hondas dont' work with the toyota, since the butting end is a different diameter. I tried.
why you need longer studs first? I still would suggest the H&R spacers if that's what your doing.
they have some nice 15mm spacers, meaning a 15mm longer stud...pretty long.
B2FiNiTY
It won't rub anywhere. The wheel studs are so far away from the wheel well!
B2FiNiTY
03-22-2005, 05:21 AM
Thanks for trying that out!
I don't NEED longer wheel studs but I wanted to go with the extended wheel stud look.
