Spark Plug change, help!
Old Sep 3, 2011 | 03:08 PM
mrsocks's Avatar
Default Spark Plug change, help!
Please help. Searched but cannot find the spark plug change DIY info. Not really interested in fancy plugs (good power and decent mpg with stockies) but need to know any intricate details r/t 21st century tech.
Last plugs I changed were on my '64 IHC 345 ci ! ! (kidding)
Any help is appreciated.
Socks
Old Sep 3, 2011 | 06:25 PM
Reactor's Avatar
DIY with pictures: http://www.clubxb.com/forums/showthread.php?t=18294
Old Sep 4, 2011 | 06:46 AM
mrsocks's Avatar
Now Das wha i'm talkin' 'bout! Thanks Reactor!!
Old Sep 4, 2011 | 10:36 AM
KiKaZ-tC's Avatar
Originally Posted by Reactor
DIY is missing important info.
-use anti-seize
-torque spark plugs to 14ft-lbs
Old Sep 4, 2011 | 02:10 PM
mrexotica's Avatar
Don't cheap out on the plugs. The arm and a leg you spend on the iridium plugs is worth it when youndo the math. You wouldn't use the same plugs in your v8 for 60-100,000 miles, would you?
Copper plugs are $8/set
Proper Iridium are $28/set. That's not bad for plugs that last around 5 times longer...
Old Sep 5, 2011 | 10:18 AM
evilBOXevil's Avatar
Knowing how to change/check your plugs is very important. Visually inspecting your plugs every now and then to see how your engine is doing is as useful as looking at the dipstick for checking your oil.
Pull them out every now and then to see what condition they are in. It tells you alot about how your engine is doing.
This chart is helpful if you need some idea of what you are looking at:
http://www.gnttype.org/techarea/engine/plugs.html
kleecker
Jul 11, 2015 09:39 PM
daniinpitt
Apr 4, 2015 08:07 PM
cid_mcdp
Jan 5, 2015 02:45 PM
06ScionTc5sp1
18
Dec 21, 2014 07:21 AM
jenkay
Dec 17, 2014 03:25 PM
