unhooking speedometer
Old Mar 22, 2005 | 06:04 AM
dougcbx's Avatar
Default unhooking speedometer
Has anyone unhooked their speedometer cable,and if so, how hard or successful was it?
Old Mar 22, 2005 | 06:36 AM
UnFocused's Avatar
I highly doubt its possible. the ABS and Trac sensors keep the speed of all 4 wheels, stored in the computer. the days of a single "cable" is gone!
Old Mar 22, 2005 | 02:02 PM
jmiller20874's Avatar
If you mean the one that connects to the gauge cluster, it's easy.
Old Mar 22, 2005 | 02:18 PM
crab_nasty's Avatar
Yeah if you are refering to the wire harness connecting to the guages, then yes it is very simple. On the xb just pop the front plastic around the guages off, then un screw the the guage so that you can pull the whole thing out and then just simply disconnect the harness. very simple. any questions just drop a pm. hope this helps.
Old Mar 23, 2005 | 06:04 AM
dougcbx's Avatar
So it's no longer a cable, but a wiring harness? I suppose by unhooking the wiring harness that you also lose everything that the gauge measures - tach, gas, odometer.
I didn't realize the speedo was activated by an electrical signal. Thanks for the info.
Old May 21, 2005 | 05:03 PM
guitarsamurai's Avatar
Anyone know what color wire the speedometer signal is on the gauge cluster connector?
Old May 21, 2005 | 07:38 PM
Munch's Avatar
Why would you want to do that anyway? I see some fishy business going on here . Tampering with the odometer is a felony in most states. I know you don't care but if your're busted you will.
Old May 21, 2005 | 10:33 PM
javier's Avatar
i think what hes talking about is how to stop the miles from piling up
Old May 21, 2005 | 11:21 PM
Piston's Avatar
you would have to pull the main computer to stop the miles from adding up. All the fauge cluster does is display the computer info. Better luck next time.
Jason
Old May 22, 2005 | 02:22 AM
Actually piston, you are wrong. There is a CPU on the gauge cluster that stores and record the mileage. The ECU calculates the speed and such and sends this signal to the guage cluster to record. Unplug your gauge cluster completely, drive a few miles and plug it back in... you'll see that there is no change.
Old May 22, 2005 | 04:42 AM
Piston's Avatar
Actually I have driven amost 500 miles without my cluster in the car, due to dash mods, and after hooking it back up the mileage did increase. Maybe on smaller chunks it will not record, but on major amounts it still calculates it.
Jason
Old May 23, 2005 | 04:54 PM
gavmitchau's Avatar
good to know! at least ppl buying 2nd hand tc's wont get shafted
07tcscion
Oct 8, 2015 05:42 PM
paisatronix
Sep 5, 2015 04:13 AM
Xaphoon
Scion tC 2G ICE & Interior
Apr 22, 2015 02:36 PM
mr_bb2u
Apr 19, 2015 04:23 PM
JDg2TC
Feb 12, 2015 01:39 PM
