Repeated Master Cyl Failure
Old Sep 4, 2011 | 06:51 PM
SoFloTC's Avatar
Default Repeated Master Cyl Failure
What could possibly cause 4 CMC's to fail in a 6 month span?! im getting tired of this, i replace it, its good for a while but pressure just slowly fades away and then bam, pedal stuck to floor. What could cause them to continue failing. Im on a comp stage 4 clutch.
Old Sep 4, 2011 | 07:02 PM
johnnyb305mia's Avatar
Again chad wtf bro this bad luck sucks...only thing i can think of is ditch the cc
Sent from my DROIDX using Tapatalk
Old Sep 4, 2011 | 07:12 PM
SoFloTC's Avatar
i cant take this anymore im going to jump off a bridge, goodbye SL :O lolol
Old Sep 4, 2011 | 08:04 PM
mrexotica's Avatar
Have it professionally installed. You'll spend less than your gas, labor, parts you've already spent...
Old Sep 4, 2011 | 11:09 PM
youngflyer's Avatar
the only thing i can think of is maybe your getting an aftermarket part or you damage it upon install?
Old Sep 12, 2011 | 03:59 PM
TotalChaos's Avatar
Are you using the proper fluid? Was it bleed correclty before install? Also, where are you getting the master cylinder from? If not Toyota, I would probably go and grab one from them to be honest.
yhwhdesign
Jun 11, 2021 03:34 PM
Andrew75
Jul 26, 2015 08:13 PM
herbn44
Jul 24, 2015 02:26 PM
Mjdavis1994
Jul 18, 2015 04:29 AM
