Scion xD Suspension & Handling Coilovers, Shocks, Airbags, Swaybars...
Alignment question
Old Sep 11, 2011 | 01:11 PM
BoryBaby's Avatar
Default Alignment question
I just went to get my car aligned and the guy told me with aftermarket shim my car will always pull and can't be aligned. Is this true?
Old Sep 11, 2011 | 01:48 PM
cobaltbravo's Avatar
We're going to need a little mmore info than that. What "shim" are you talking about? If you're talking about wheel spacers, that's not true. If you're talking about 0 degree hub spacers in the rear, that's not true. If you're talking about that the actual shims (red rings) that are available for your rear hubs, you only need them if there's something wrong with your rear alignment already (tweeked from accident for example).
Sent from my rooted Droid
Old Sep 11, 2011 | 03:24 PM
BoryBaby's Avatar
That's what I thought. I mean I've had it aligned a few times. What he's telling me is that my car will continue to Pull to the left with a shim kit ( his words) installed which they don't make for the xD. I understand that wheel spacers make the wheel stick further out so It doesn't rub. Rear alignment is fine on the car and realistically the pull is very little but I want it fixed.
Old Sep 11, 2011 | 03:42 PM
They make a shim kit for your rear hubs, and camber bolts for your front suspension. If you're car is pulling to the left, thats usually a toe in/out problem as I understand it. I believe you adjust the tie rods to fix that.
Old Sep 11, 2011 | 07:41 PM
Vlad1024's Avatar
no one will be able to give you advise without seeing your alignment report.
bootlgr
Jan 26, 2016 01:22 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
xBassist
9
Jan 21, 2004 07:34 PM
JDMxB
13
Dec 23, 2003 04:23 AM
