Rear toe alignment needed?
Old Sep 12, 2011 | 02:33 AM
tokenecho's Avatar
Default Rear toe alignment needed?
Looking for advice. My left rear wheel toe alignment is out 6/32nds. Is it worth having it shimmed? Is 6/32nds a lot? And if so, what shim kit should I use on my 2nd gen xb? Oh, I should mention that I'm replacing my Nitto Neo Gen 225/40/18 tires with another set of the same. Tires coming off have 28K miles with inner edge tire wear. Car is not lowered and has 100% factory suspension. What are your thoughts?
Old Sep 12, 2011 | 11:37 PM
xseveredveganx's Avatar
Utah Scions
You could shim it, but you have to remember that the brake caliper is mounted on the same plane as the hub itself. Therefore, the caliper should probably be shimmed, too.
I've yet to get the rear shimmed at all. Then again, my tires rarely last me longer than a year.
kleecker
Jan 2, 2015 08:09 PM
rancur3p1c
Dec 19, 2014 04:30 PM
SkateVandal
Scion xB 2nd-Gen Wheel & Tire
Nov 27, 2014 02:34 AM
XB_2
Nov 23, 2014 02:48 PM
JDMxB
13
Dec 23, 2003 04:23 AM
