Help! Throwing CEL Codes P0113,P0441,P0455
Old Sep 13, 2011 | 02:08 AM
the_butcher's Avatar
Default Help! Throwing CEL Codes P0113,P0441,P0455
P0113 - Intake air temperature circuit high input
P0441 - Evaporative emission control system incorrect purge flow
P0455 - Evaporative emission control system leak detected (gross)
Just the other day my Gf's CEL came on... These are the codes.
The car is an 06 tC 5 speed coming up on about 100,000 miles with a K&N Cold air intake.
Can anyone help with suggestions on what I could start checking or replacing.
For additional info, about 2 weeks ago we made a 400 mile trip up north and before the trip i noticed a low bumpy idle, so i bought MAF cleaner, and cleaned the MAF. The car idled awesome and the car was no problem until recently. The car feels like it drives fine, I haven't noticed it myself yet but my GF mentioned it stalled a couple of times on her today and had a low choppy idle.
Thanks for the help.
Old Sep 13, 2011 | 11:12 PM
mrexotica's Avatar
Search the Internet for the detailed explanations for the codes.
With evap codes, it could be as simple as a $25 gas cap. Or it could be expensive.
Old Sep 14, 2011 | 10:00 PM
myr6goesfast's Avatar
I'm getting the P0441 & P0455 codes and I'm 99% sure it's my gas cap... it doesn't lock. Just sitting over the opening.
Old Sep 14, 2011 | 11:34 PM
mrexotica's Avatar
Very clearly, you need a new gas cap...
Old Sep 15, 2011 | 06:57 AM
Sweet, going to change over the K&N CAI to stock and get a new gas cap.. sucks Cause this is the 2nd gas cap in the past 4-5 years
Old Sep 15, 2011 | 09:02 AM
sciontc_mich's Avatar
i've heard this before.. on my old car, i had to replace those gas caps every 2-3 years. The seal would age, flatten out, and start leaking.
You might also want to check the fuel filler neck lip for any corrosion where the gas cap gasket seals against the lip. Any corrosion there would cause a leak against the gas cap gasket. But if you find any corrosion then stuff a rag into the filler neck and use a green scrubby to make it clean again. the rag is there to stop anything getting into your gas tank when you scrub off any corrosion from the filler lip. definitely dont want bad stuff in the gas tank
about that code of "intake air temp" that sounds like the MAF sensor alright.. it has the IAT (idle air temp) on the side, that amber bulb looking thing is the IAT. The MAF is the two dental floss wires down the tube. If you're using CRC's MAF sensor cleaner and waiting for it to dry before reinstalling, then I'd say that it's clean, and you have a bad MAF sensor.. Try cleaning it again one more time, clear the code, and see if that IAT code comes back.
Old Sep 15, 2011 | 04:46 PM
fongyz's Avatar
As with the MAF sensor going bad; did she recently do anything electrical around / with the battery? I touched a socket wrench off the positive terminal to the MAF sensor area by accident, spark! MAF died and rough idle. Replaced it (~$80) and works. didn't measure CEL codes though cuz I knew what I did wrong lol.
Old Sep 16, 2011 | 01:23 AM
mrexotica's Avatar
K&N is reputable. Do one thing at a time.
MeDizzy
Oct 8, 2015 03:31 PM
Gigs
Sep 15, 2015 03:54 AM
mw1957
Jul 28, 2015 06:04 AM
mw1957
Jul 28, 2015 05:31 AM
rancur3p1c
Jul 12, 2015 07:59 PM
