Has anyone tried 16" rims?
Old Sep 22, 2011 | 09:32 PM
KyleG's Avatar
Default Has anyone tried 16" rims?
Hey all, Ive got a set of winters on some 16" rims from an Oldsmobile I use to own. The bolt pattern and tire diameters line up, but im not sure if the rims will clear the brakes.
Has any one tried fitting 16's yet?
Old Sep 22, 2011 | 09:53 PM
Blackedout011TC's Avatar
Spare is a 16" so yes. The offset, center bore and rolling diameter are other factors you need to check.
Old Sep 22, 2011 | 10:02 PM
KyleG's Avatar
Thanks for the info! I didnt think of checking the spare.
Old Oct 22, 2011 | 03:40 PM
ryan2339's Avatar
I'm using a set of 215 60R 16s for the winter the jus barely clear the front calipers
Old Oct 31, 2011 | 03:42 AM
NickF127's Avatar
I just bought a set of 215/60R-16 Blizzak WS-70s, I need to buy steelies 16x6.5" steelies for them, anyone know the offset I need? And 16" rims should work fine, I think it might even clear those with the BBK because the spare is a 16"
Old Oct 31, 2011 | 04:05 AM
ryan2339's Avatar
I bought my steelies from a guy that had an 08 camry with a 45 offset and they fit perfectly. I highly doubt bbks will clear 16s since the stock brakes just barely clear 16s. You would need 17s at least to clear bbks.
Old Oct 31, 2011 | 04:16 AM
NickF127's Avatar
Thanks man
Old Nov 6, 2011 | 06:44 PM
integlspwr's Avatar
16s might look a big small ?
Old Nov 7, 2011 | 03:01 AM
NickF127's Avatar
ryan says hes sitting on them now. I'll take pics when I mount mine
Old Nov 8, 2011 | 01:53 AM
hypor's Avatar
would 15inch fit at all?
I found some dirt cheap steelies with winters on and on tire calculator comparison
its just 3.82% smaller
Old Nov 8, 2011 | 01:57 AM
NickF127's Avatar
It might not clear the frpoont brakes though, even though teh overall diameter is the same-ish... see if they guy will let you see if they mount?
eujin
Feb 23, 2016 01:18 AM
axB
Sep 18, 2015 06:11 AM
peruviann
Sep 14, 2015 06:35 AM
Robineileen324
Sep 14, 2015 06:21 AM
JZA70
Sep 12, 2015 09:37 PM
