Engine Rebuild @185,000 miles...
Old Sep 28, 2011 | 07:03 PM
krazykoo's Avatar
Default Engine Rebuild @185,000 miles...
Hey guys, I finally decided to rebuild my motor after 185,000 miles. It was been put back to stock the last year, but had a turbo in it the previous three years. Motor ran fine with turbo and tune. It was running fine after putting it back to stock until a couple of months ago. It was misfiring and I performed a compression check and cylinder three was at 60psi. This pass weekend, I tore down the motor and found out that three pistons had broken ring lands and piston three was starting to detonate. It was odd that the three pistons had broken ring lands at the same spot of the pistons. Can it be a poor design from toyota? Well, enjoy the pictures guys! Even with broken ring lands, they were still pushing out 120psi. I do have a question for everyone. Where can I find oversize pistons with the stock compression ratio? Or do I have to custom order them?
Thanks,
Kue
Old Sep 28, 2011 | 09:04 PM
pstoltz89's Avatar
at what mileage did you turbo your tc?
Old Sep 28, 2011 | 09:25 PM
krazykoo's Avatar
I had it turbo around 50,000 miles.
Old Sep 29, 2011 | 01:27 AM
tcturbo07's Avatar
wow thats alot of boosted miles you put on in three years. how much boost did you run?
Old Sep 29, 2011 | 01:40 AM
krazykoo's Avatar
Yeah, hella miles commuting back and forth during those college years. I was boosting around 10psi.
Old Sep 29, 2011 | 02:58 AM
1E0_Tc_05's Avatar
How worn are the cylinders?? Was the car running sluggish before you tore it apart? What was you driving like? Light ? Medium? Or lead foot?
Old Sep 29, 2011 | 03:01 AM
pstoltz89's Avatar
what kit did you have and what kind of miles did you put on the car? Long distance drives or was it mostly city driving?
Old Sep 29, 2011 | 04:05 AM
krazykoo's Avatar
The cylinders were in great shape except for cylinder three in the pic. It had a small dent. The car was running sluggish before I took it apart. It would studder and die out when the ac was on. I drove it normal after the turbo was off cause I was trying to baby it so it wont blow up. I started out with a greddy kit and then finished off with a dezod kit with a different turbo. I was driving a combination both highway and city.
Old Sep 29, 2011 | 08:25 PM
joohnn's Avatar
you should do the rebuilt with some high comp pistons and do an NA build
Old Sep 29, 2011 | 10:25 PM
krazykoo's Avatar
Yeah I really want to do a NA build, but I'm not sure about having it pass CA smog. I would have to get pistons, rods, cams, and stand alone to make it worth building a NA. All that is gonna add up quick. LOL!
Old Oct 1, 2011 | 11:53 AM
mrexotica's Avatar
If you bought your second turbo from Dezod, I would talk with Dezod about the proper rebuild parts. He works with DG Spec Dan Gardner's Turbo tC race car.
RayScionXB
Regional - Pacific South
19
Mar 5, 2015 08:22 PM
RayScionXB
Regional - Everywhere Else
Mar 3, 2015 08:27 PM
Ramroids55
Jan 16, 2015 02:42 PM
TheTripleC
Jan 4, 2015 06:46 PM
