Cable Throttle Body
Old Oct 10, 2011 | 05:51 PM
thendawg's Avatar
Default Cable Throttle Body
Just curious if anyone has gone to a cable throttle body on the tc. If so, which throttle body and pedal assembly did you find to work well? I have no problem doing the legwork on this myself, but just wanted to see if someones already done it first and found a good working setup. No reason to reinvent the wheel.
Old Oct 10, 2011 | 06:32 PM
thendawg's Avatar
FYI my current idea is a pedal/throttle linkage from a gen 1xb (Ive found a couple at local junkyards I could go look at) than maybe an aftermarket 70mm throttle body designed for a Honda (they use a pretty easy-to-machine-for 4 bolt pattern similar to ours. Ill probably stick with the stock intake manifold and just make an adapter plate.
Old Oct 10, 2011 | 07:03 PM
DTC08's Avatar
Not sure what good that would do or what you're trying to accomplish, but someone threw an rx-8 TB onto the tc with minimal wire splicing and that is a larger TB from the RX-8... search on here
Old Oct 10, 2011 | 07:08 PM
thendawg's Avatar
Has nothing to do with sizing. Simply trying to go to a cable throttle body when I wire up the MegaSquirt 3x. As far as I know, theres no way to use it with an electronic throttle body. Ive thought about tricking the ECU into still controlling the throttle, but id perfer not to, and this really shouldnt be that difficult (on the scale of things Ive done to this car) haha. Just wanted to see if anyone had done it, and if so which throttle body and pedal they used.
Old Oct 10, 2011 | 08:06 PM
XPRTc's Avatar
https://www.scionlife.com/forums/sho...ighlight=alpha
silvrtc300 did one. He used Chris Rado's intake manifold/ cable TB off of the Vs.1 T/A though. Probably doesn't help though, sorry...
Old Oct 10, 2011 | 08:13 PM
XPRTc's Avatar
**correction the intake manifold was from the T/A car, but on post #112 he mentions that he fabbed it out for a 70mm cable Honda BBK throttle body.
Old Oct 10, 2011 | 08:21 PM
thendawg's Avatar
I really appreciate it, I was searching for that particular thread but couldnt remem who the OP on it was.
Old Oct 10, 2011 | 10:29 PM
silvrtc300's Avatar
what ECU are you running?
Old Oct 10, 2011 | 10:32 PM
silvrtc300's Avatar
There are a small hand full who converted to cable. I used a 75mm BBK Honda throttle body, with a intake manifold from World. With a modified stock pedal base infused with a RAV4 cable and arm of the rav4 arm. a few adjustments is definately need to make it work just right. but it was the simplest way.
Old Oct 10, 2011 | 10:58 PM
thendawg's Avatar
Im currently using an EMU, but planning on going to a MegaSquirt 3x soon. I really appreciate the info, looks like it wont be too hard to do.
Old Oct 11, 2011 | 02:20 PM
silvrtc300's Avatar
I have a a megasquirt system full put together if you are interested i'll let it got for good price.
Old Oct 11, 2011 | 02:22 PM
silvrtc300's Avatar
Its not all that complicating. The older rav4 with the 2.4 were cable driven.. for it's a good base to start from. I wasn't sure if the throttle body would work so i didn't even bother with it. I was upgrading to a honda BBK so I chose the route I did. Let me know how yours go.
Old Oct 11, 2011 | 02:25 PM
silvrtc300's Avatar
Old Oct 11, 2011 | 06:08 PM
thendawg's Avatar
Silver, which MS is it? Im really wanting to go with an MS3x, if it doesnt have the x daughterboard installed, thatd be ok, its not too much of a pain to install it.
Old Oct 11, 2011 | 06:56 PM
silvrtc300's Avatar
It is the MS3 whether its the X or not is a good question, but it is the main box, and a secondary control unit with it and harnesses. I'll look into it more for u..
Old Oct 11, 2011 | 07:40 PM
thendawg's Avatar
Yeah the X is just a daughterboard, f it came with it, it should have an additional large connector that looks like an oldschool parralel printer port
Old Oct 19, 2011 | 03:43 PM
JMANTC's Avatar
What is the advantage to this?
knuckleheadjcz
Dec 24, 2015 09:07 AM
MeDizzy
Oct 8, 2015 03:31 PM
Geedavell
Scion xD ICE & Interior
Sep 28, 2015 01:33 AM
prescottn
Sep 13, 2015 09:04 PM
Subaru86
Scion FR-S ICE & Interior
Sep 10, 2015 08:11 AM
