Engine Assembly - RTV ?
Old Oct 11, 2011 | 04:10 PM
maple's Avatar
Default Engine Assembly - RTV ?
The Toyota sealant used to seal the oil pan and cam chain case is hard, seems much harder when set than the average RTV sealant.
My question is RTV the best to use for reassembly, any experience with quality of seal with RTV on the TC's.
Same question on brands, Permatex? Hi Temp or regular temp as oil pan and cam chain will not be reach high temps.
Old Oct 11, 2011 | 05:05 PM
thendawg's Avatar
Id recommend using the Toyota FIPG. You can get it from any dealer for around $7 or so per tube, not much more than regular RTV. It may sound crazy, but oil pan wise, mine leaked both times I was in a pinch and used Black RTV. Never had it leak one drop with FIPG. All 3 motors I assembled have been all with FIPG also.
Old Oct 11, 2011 | 05:29 PM
PeArLwHiTe07tC's Avatar
yea fipg is the best bet... part # is 00295-00103. dealer list is $13.84...
Old Oct 11, 2011 | 10:50 PM
browniemxn's Avatar
fipg is the bomb and all but getting the stuff off is a different story. Make sure it is what you want before you let it cure! My weld on my oil pan was leaking but I never thought to check it before hand. Doing your oil pan twice isn't fun!
Old Oct 12, 2011 | 12:14 AM
trd07tc's Avatar
toyota sealant only
Old Oct 12, 2011 | 05:35 AM
maple's Avatar
Thanks all for the response, I will use Toyota sealant and check the oil pan weld as well before making it one again.
Appreciated !
Old Oct 12, 2011 | 11:12 PM
willerdcraft's Avatar
Having the same problem used RVT and the bugger is leaking, only a tiny amount though but its annoying.
Anyone used the gasket that you can get online?
Old Oct 13, 2011 | 02:23 PM
paul_dezod's Avatar
Scionetics
KAD
Toyo Fit In Place Gasket is the best
Old Oct 14, 2011 | 03:46 AM
ScionFred's Avatar
The Right Stuff from Permatex is also an excellent choice.
NonStopTuning
Jun 29, 2015 07:42 PM
S7ephavs
Mar 22, 2015 12:09 PM
fur_pig
Scion tC 1G ICE & Interior
Jan 27, 2015 12:52 PM
Miqmiqmiq
Jan 15, 2015 03:30 AM
vitkh
Nov 30, 2014 02:27 PM
