The finest in fuel injection is here at Dezod...
Old Oct 12, 2011 | 09:19 PM
paul_dezod's Avatar
Scionetics
KAD
Default The finest in fuel injection is here at Dezod...
Not only do we carry Deatsch Werks, but we also now offer Injector Dynamics!
We will be stocking 725s and 1000s. Our stocking order should arrive sometime in the next few days.
Dynamically Matched Sets
Injector Dynamics fuel injectors are the result of batch testing large quantities of specially modified fuel injectors, and then carefully matching them into sets based on their dynamic flow across the pulsewidth range. The result is vastly superior cylinder to cylinder consistency, even at very low pulsewidths.
In addition to receiving tightly matched injectors, you will be provided with dead time compensation values across the entire pressure and voltage range of the injector. This data will insure that the compensations in your ECU work properly, and your air fuel ratios will remain consistent as atmospheric or voltage conditions change.
Full Dynamic Characterization
We provide the data that you and your ECU need to do the job properly.
Flow and offset values are provided from 8 to 16 volts across the full pressure range in 5 psi increments.
Additionally, we publish full dynamic characterization curves: Raw flow vs pulsewidth, offset corrected flow, linearity curves, and pressure sensitivity plots.
More info:
http://www.dezod.com/pd-injector-dyn...7-xb-08-10.cfm
Old Oct 12, 2011 | 09:29 PM
MDTC713's Avatar
T1 integra thats one fast teg
Old Oct 13, 2011 | 12:55 PM
paul_dezod's Avatar
Scionetics
KAD
Yeah, Tony's Integra is no joke.
Old Oct 13, 2011 | 02:05 PM
swomack's Avatar
yes! mmmm ID1000s.
Old Oct 13, 2011 | 02:08 PM
paul_dezod's Avatar
Scionetics
KAD
Originally Posted by swomack
yes! mmmm ID1000s.
Will be in stock early next week ready to ship.
Old Oct 15, 2011 | 01:41 AM
Ace83's Avatar
Ronin Scion
the 2000cc is a low impendance or still a drop in injector?
Old Oct 15, 2011 | 11:19 AM
trd07tc's Avatar
2000cc is high impedence
there like $900
Old Oct 16, 2011 | 06:55 PM
GetIt's Avatar
Shoot me a PM with prices for 1000CC guys, possibly larger for my Z33 build.
Old Oct 17, 2011 | 02:43 PM
paul_dezod's Avatar
Scionetics
KAD
High Impedance
PM sent.
Old Oct 19, 2011 | 04:56 PM
paul_dezod's Avatar
Scionetics
KAD
In stock!!!!!
Old Oct 25, 2011 | 03:19 PM
paul_dezod's Avatar
Scionetics
KAD
Free shipping and a free k&n oil filter for your next oil change when you purchase these!
While supplies last.
Old Oct 25, 2011 | 06:01 PM
Syldrin's Avatar
wtb PnP harness >.<
Old Oct 25, 2011 | 06:07 PM
paul_dezod's Avatar
Scionetics
KAD
Originally Posted by Syldrin
wtb PnP harness >.<
Working on sourcing the connector, if I can, I will be able to make them no problem.
Old Oct 25, 2011 | 06:26 PM
Syldrin's Avatar
I just wanted to make sure I have you a hard time
Sent from my ADR6300 using Tapatalk
Old Oct 25, 2011 | 07:45 PM
paul_dezod's Avatar
Scionetics
KAD
You're winning then.
steeze69
May 24, 2021 02:57 AM
mudguy
Oct 22, 2015 04:31 PM
MeDizzy
Oct 8, 2015 03:31 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
paisatronix
Sep 5, 2015 04:13 AM
