*LEDmod Daytime Running Light DRL for xB
High Power Daytime Running Light for Scion xB 08 an UP
Benz style DRL
It's so much brighter than Benz Stock DRL, see the comparison below
You can see them clearly during daytime and seen from far away
Easy installation, just need to drill two hole and run any two wires to 12v power source (mine is tap to cig lighter, which make it turns on when ever car is on)
- Using 12 0.5 Watt High Power LED to make it daytime visible
- Powered by any 12v source
Direct order page here
Scion xB2 (11 and up)
Benz style DRL
So it won't be perfectly designed for xB
But it's close fit and doesn't require modification to stock parts then drilling two hole on the vent cover to mount.
I had these installed by Sean at LED Mod. I drove over during my lunch, and he installed them in about 1 1/2 hrs. Did an excellent job. He even installed an on/off button. They look great and are really bright. Highly recommend these lights, you will like them.
