I spent MORE than the bare minimum on my suspension!!!
Old Oct 19, 2011 | 02:56 AM
mrexotica's Avatar
Default I spent MORE than the bare minimum on my suspension!!!
What's your functional suspension setup?
Mine:
Hotchkis Sport rear sway bar
Front bar disconnected
Koni yellow strut inserts/shocks
Ground Control coil over sleeves
Eibach springs 400lbs front/700lbs rear
It cost me more than $200.
I didn't buy one piece on eBay.
I did my best to buy from a face.
Old Oct 19, 2011 | 03:22 AM
Roller_Toaster's Avatar
you DD with no front sway? I can understand disconnecting it before auto-xing.
Old Oct 19, 2011 | 06:55 AM
AcidDrop's Avatar
i think a thread like this has been made already but here's mine
Function & Form Type-2 coilovers
(8kg springs f/r, thinking of switching the front to 12kg)
TRD front strut bar
TRD rear sway bar w/ES bushing
DME rear strut bar
Energy suspension motor mounts
BFGoodrich G-sport tires (do tires count too?)
Want to get the Energy Suspension master bushing kit
Old Oct 19, 2011 | 01:04 PM
torqueTc's Avatar
TRD shocks + struts, TRD springs, TRD front strut bar/TRD rear sway. GGP solid motor mount..
Old Oct 19, 2011 | 02:38 PM
Rockztar's Avatar
Progress rear sway bar
d2 coilovers
ebay strut bar (since it doesn't do much on the tc lol)
ingalls 4 point brace
megan c-pillar bar
Old Oct 19, 2011 | 04:56 PM
mrexotica's Avatar
On the street, there's minimal difference.
However, I wouldn't recommend it unless you have at least 400lb springs (the corners have more work to do) and serious dampers to handle serious springs.
For autocross, the car feels a little looser, but turns a LOT better. Even with 400lb springs, Ive bottomed out on a downhill, bumpy turn. That club decided against that design after that.
That is one of the adjustments I credit with me finally beating my rival's Impreza after 4 years of trying.
Old Oct 25, 2011 | 11:38 PM
mrexotica's Avatar
Old Oct 25, 2011 | 11:40 PM
mrexotica's Avatar
I would have called the post "I dropped my tC 7" on $199 coil overs and $29 strut bars" and there would be 100 posts!
Glad to see there are two or three others concerned with quality...
Old Nov 10, 2011 | 04:37 AM
pinoyFMtC's Avatar
Hotchkis Springs (wish I could get something else, it's too low and too soft)
DG Spec Rear Swaybar
Tokico HP Shock/Strut
Camber bolts with -2F -1R
Looking at possibly getting Ground Control/Konis eventually.
Old Nov 10, 2011 | 05:02 AM
Generic STB, Hotchkis springs + sways here, soon to be on Ksports (whenever I get around to installing them)...that are (gasp) NOT slammed as low as possible, and still allow my front suspension to function!
Soon to be upgrading to general gmax as-03's as well.
Old Nov 10, 2011 | 05:16 AM
carben100's Avatar
Tokico HP Shocks/Struts
H&R Sport Springs
Progress RSB
Old Nov 10, 2011 | 06:05 AM
Vang2k's Avatar
Tein H techs, Koni Yellow Shocks, TRD Rear sway bar
Old Nov 12, 2011 | 05:31 AM
rUsh559's Avatar
Tein SSP w/ EDFC
TRD Front Strut
DG Spec Rear Swaybar w/ ES bushings
Ingalls 4 point brace
Hopefully soon to be GGP mount and Megan C-Pillar :p
Old Nov 14, 2011 | 12:55 PM
ChupacabraTX's Avatar
KW Variant 2 Coilovers
TRD rear sway bar
Continental CSC3 tires
(no strut bar, no harness bar)
I tried to spend a little less than 2 (thousand)...and I missed it by $40 bucks after alignment.
The best benefit to spending more on these is in the 2 years I've had them on my car and numerous autox events, I haven't had to repair a damn thing.
Old Nov 14, 2011 | 01:09 PM
mrexotica's Avatar
Holy crap!
No strut bars?!?
Sounds like a great setup.
How do you like KW's? I almost got some when I did my setup, but they were above my budget.
Old Nov 14, 2011 | 05:52 PM
paul_dezod's Avatar
Scionetics
KAD
Originally Posted by mrexotica
Holy crap!
No strut bars?!?
From experience, KWs are awesome, but quite stiff on the ride around town if your streets are littered with pot holes like ours are.
Old Nov 14, 2011 | 06:04 PM
mrexotica's Avatar
Yeah.
I've got some pretty stiff springs that have given some awakening drives, but On the whole, the tC suspension surprises me at how good the ride can be with serious springs. I'm using 700rear/400front, and am looking to raise rates a bit for 2012. I don't feel like I can go much higher for street driving though. The trick is finding that fine line...
Old Nov 15, 2011 | 07:56 PM
Paul, you are right on the money. Although, here in MN the roads near me have been repaved so it's smooth running. I would say the KW's and Tein's are almost identical in quality, but I wanted something different.
mrexotica, I wouldn't hesitate to buy them again because I know after almost 2 years of ownership with these coils that there are zero problems.
Old Nov 15, 2011 | 08:10 PM
mrexotica's Avatar
I've heard many good things about KW from racers. I can live with the fact I won't have JDM cred...;-)
Old Nov 15, 2011 | 11:06 PM
Chrisb319's Avatar
currently I have
Tokico HP shocks
Hotchkis Springs
Hotchkis F&R sways
TRD Polished Strut Tower
I had the Ingalls Floor brace but lost it because of my subfloor
DC Sporsts strut tower.
