which coilover do u think is better?
Old Oct 19, 2011 | 03:52 AM
Coolwaterz's Avatar
Default which coilover do u think is better?
im not sure what to get right now. all three is about the same price.
Function and Form type-2
KSport Kontrol Pro Damper
Megan coilovers
im leaning towards the type-2s.
Old Oct 19, 2011 | 06:45 AM
AcidDrop's Avatar
F&F type-2 hands down, mine are pretty comfortable or at least they are to me. sure they don't go really low but i didn't get mine to be slammed so that doesn't matter to me unlike others...
Old Oct 19, 2011 | 07:49 AM
Coolwaterz's Avatar
thanks i had a feeling that one was better overall. i wont be slamming. these roads over here are bad and i just just barely dropped with TRD springs..
i just hate the TRD spring and stock shocks. surprised it lasted this long. 30k miles and going.
Old Oct 19, 2011 | 08:31 AM
dropzone's Avatar
I had TRD springs on stock shocks for about 19K and no problems. Now I'm lower with B&G RS2 coilovers and wouldn't change for [almost] anything else. Also check out BC coilovers, make some calls or PM vendors here for pricing, they can also slam when you get that itch for it. But if it has to be of the three listed then FF Type-2.
Old Oct 19, 2011 | 05:06 PM
mrexotica's Avatar
What do you want to accomplish?
Drop?
Ride?
Handling?
Old Oct 20, 2011 | 03:31 AM
Coolwaterz's Avatar
Drop?
Ride?
Handling?
im just going to get FF type-2. im not looking for drop. i might even go a little higher then TRDs to save my car...
main reason is that im doing this is my rear shocks are dying (i think going to get it check out at a friends garage)
but handling would be so much better overall.
Old Oct 20, 2011 | 02:01 PM
hnyuH_divaD's Avatar
I was on FF type 1, Man it got bad really quick. I was maxed maxed out in the rear and fronts were leveled to match and they were slightly used but still. I just ordered a set of BC Racing type BR coilovers (With EDK), From what i've seen in person from friends and people in Houston's car scene, the best bang for the buck. Top notch build quality and the rebuild is only 95 bucks for each shock after the 1 year warranty.
Old Oct 20, 2011 | 05:47 PM
etoomey3's Avatar
I say FF2, I have them on my car, have had them for a good 40K miles, and I love them. I have also heard Great things about BR coilovers as well.
Old Oct 23, 2011 | 05:09 AM
mrexotica's Avatar
If you're not going lower, don't waste your money. Get some good quality struts, like Koni or Tokico, and good quality springs like Eibach Proline. They have a mild drop.
Most of the coil over companies don't even publish their spring rates. That would lead be to believe the majority are just built for looks, which to me is a waste of money.
Personally, I use Koni yellow inserts with Ground Control. I daily drive the car, and autocross it (just won regional champ over an Imprezza, beating AWD in the rain...)
Old Oct 23, 2011 | 05:27 AM
dropzone's Avatar
^The spring rates for most of them are known, and a chart was made but think needs updating though. Even then a call to the company can solve that. Even then if one really wants a setup to handle they'd go with a coilover that has a higher rear spring rate instead of the even 8k F/R that many offer(which Function Form uses). One really has to do their homework if they're wanting a functional setup.
Old Oct 23, 2011 | 04:11 PM
mrexotica's Avatar
What he said!
The only coil overs I would use on my auto crosser are KW. I would probably change the springs to suit my taste though, but they are HIGHLY recommended among RACERS.
Old Oct 24, 2011 | 01:14 AM
Spicy_McHaggiz's Avatar
Because ff-2s aren't for slamming your car. If you want to slam get racelands.
Old Oct 24, 2011 | 01:57 AM
I got them for a good deal. And why would I get racelands when I just said I ordered BC coilovers..
Old Oct 24, 2011 | 02:21 AM
dropzone's Avatar
^This, slam AND a good ride Raceland does not offer. It's just temporary, there's posts about having to go through shock replacements, and multiple times. That setup just can't handle it, you need something where the ride height adjustment is INDEPENDENT of spring preload to get low and maintain a comfortable ride. You see them now changing their setup to BC BR or Stance or B&G.
Old Oct 24, 2011 | 04:35 AM
mrexotica's Avatar
Old Oct 24, 2011 | 06:03 AM
dropzone's Avatar
^haha, think this can be closed now.
Old Oct 24, 2011 | 07:23 AM
Coolwaterz's Avatar
u can shorten the who setup with FF2s not racelands. i would think u can slam it with FF2s if u look at the videos about it. i believe it shortens 4"s..
Old Oct 24, 2011 | 09:26 PM
dropzone's Avatar
If I recall, the rears slam on the FF Type-2s, the front's don't. The FF Type-1 the fronts slam, the rear not so much.
Old Oct 25, 2011 | 11:35 PM
mrexotica's Avatar
You guys concerned with slamming your cars need to get a '64 Chevy with hydraulics!
Old Oct 25, 2011 | 11:36 PM
mrexotica's Avatar
-and buy all your parts from JCWhitney - they're the cheapest around!
