which strut should i use??i
Old Oct 19, 2011 | 09:20 AM
tracysilverscion's Avatar
Default which strut should i use??i
I Have h techs on stock struts with a 18x8inch wheel 35 offset slight rub.I wanted to go stiffer but I can't seem to find the right combo with h techs.I know h techs are a luxury spring and are ment to compress a lot but I need a strut that will counteract that.what do you guys recomend for a little less compression travel in my shocks??thanks any info is appriciated
Old Oct 19, 2011 | 02:34 PM
Spicy_McHaggiz's Avatar
A strut really won't give you what you need. (That and I believe there are only 1 or 2 adjustable struts for the tC anyways)
Old Oct 19, 2011 | 05:04 PM
mrexotica's Avatar
First, if you're rubbing, you have a wheel/tire combo wrong.
Second, as someone already said, the strut won't necessarily do it. Koni yellows WILL help, but, as you said yourself, your springs are soft.
Get your wheel/tire combo straightened out first. Don't bandaid your car.
Only then, get Eibach Sportline springs. They are a bit stiffer, and actually have a warranty.
I have a feeling, though, that you're going stiffer to bandaid your wheel/tire choice.
Old Oct 19, 2011 | 05:21 PM
I checked those eibach springs they are 2 inch drop all around and I didn't want to go that low in the back.I belive with the h techs I got 1.8 in the front and 1.5 in the rear but I guess a smaller tire would make sense.thanks all any other sugg.?
kb1sxv
Oct 21, 2015 05:00 PM
babyfac3pn01
Oct 19, 2015 07:24 AM
Scionxa180
Aug 30, 2015 04:12 PM
Scionxa180
Aug 30, 2015 03:50 PM
goatbelly
Jul 12, 2015 10:13 AM
