Calling S/C owners, how did you guys get these bolts off???
Old Oct 20, 2011 | 03:09 AM
gqdabien's Avatar
Default Calling S/C owners, how did you guys get these bolts off???
In process of removing s/c as noted by other thread, can't say things went swimmingly but, i'm having trouble with this one bolt!
It broke one of my 14mm wrenches already Am i using the wrong size?
Also the three allen wrench bolts holding the shaft to blower can't seem to back all the way out because of the exhaust manifold shield. I tried to unbolt the shield but can't come off because the S/C shaft is in the way! What a dilemma, looks like i might needa take off the blower first.
Any and all tips would help!
Old Oct 20, 2011 | 04:03 AM
SoccerBoy_AP's Avatar
Oye!
That does look like a bit of a pickle.
I think your assumption is correct... removing the entire supercharger is your answer before you can access the impeller shaft.
Just a recommendation, if you are going to have it off the car... replace all the seals and make yourself a grease fitting on the pulley side.
The grease fitting will extend your bearing life and the new seals will prevent the stock inevitability of breaking... thank you TRD....
Rebuild kits: http://www.superchargedscions.com/5652.html
Grease fitting: check with Gompka, he has details on how to...
Old Oct 20, 2011 | 04:26 AM
thendawg's Avatar
Ive taken off much worse 14mm bolts using my trusty craftsmen 14mm wrench (using the closed end) - ive used a long piece of 1.5" tubing to make it a giant breaker bar
Old Oct 20, 2011 | 05:12 AM
gqdabien's Avatar
Originally Posted by SoccerBoy_AP
Oye!
I'm not sure of all the parts and proper names for supercharger parts, but my plan is to rebuild the whole thing, and replace the bearings and seals. What is this grease fitting on the pulley side? Does the pulley side bearings not have any grease to begin with? I will find out when i get this thing open.
Old Oct 20, 2011 | 05:14 AM
gqdabien's Avatar
Thanks , i had used a 2" metal tube to transform my wrench into a breaker bar, and this was the result. I'll try it again with a higher quality wrench. They sell a 6 point closed wrench?
Sorry for the n00b question.
Old Oct 20, 2011 | 06:41 AM
MrBurrito's Avatar
are you trying to loosen the bolt smooth and slow? instead just hit the extension bar with your palm or rubber malet quick and fast to provide quick jolts tothe bolt and loosen it thats how i got my buddy's s/c off
Old Oct 20, 2011 | 06:55 AM
gqdabien's Avatar
i tried to do it slow and steady, in one long pull. But when i pick up a new wrench tomorrow ill try quick jolts. Thx.
Old Oct 20, 2011 | 01:52 PM
KiKaZ-tC's Avatar
That bolt shouldn't be difficult to remove, it should have only been torqued down to 14 ft/lb. Try combining two wrenchs for extra leverage and torque.
Honestly, by the looks of things, it seems like your going backwards. You should be removing the s/c from the s/c tranny bracket or unbolting the bracket directly off the tranny.
I don't know if you have installation instructions, but you should use it by starting from the end of the guide and following the instructions backwards.
http://www.trdsparks.com/install/PTR41-21070inst.pdf
Old Oct 20, 2011 | 04:41 PM
gqdabien's Avatar
Yeah my original idea was to just take off the shaft and leave the blower in if I can. I saw someone's youtube video do it that way, thats why i took off the 3 allen bolts on the horseshoe bracket.
But yes, now I will be unbolting the 3 allen wrench bolts from the S/C transmission bracket as well. Thanks for the link to the PDF!
Old Oct 20, 2011 | 10:45 PM
creamyxb2's Avatar
what is that a china wrench. any who that bolt comes out wiht the sc. it to long to sneak it out. why are you removing it.
Old Oct 21, 2011 | 08:15 AM
gqdabien's Avatar
Update, got the bolt off with another wrench and pipe. Bolt came off and so did the shaft side of supercharger. Thanks everyone for the help.
NonStopTuning
Jun 29, 2015 07:42 PM
cid_mcdp
Jan 5, 2015 02:45 PM
kahsperr
Regional - Pacific South
Jan 3, 2015 05:09 PM
minter66
Dec 15, 2014 01:45 PM
DjFrOsT
Dec 13, 2003 04:18 AM
