Throttle Body Connections
Old Oct 20, 2011 | 07:06 PM
maple's Avatar
Default Throttle Body Connections
I have looked everywhere for a Vacuum diagram for the 2009 TC, I cannot find it, if anyone has one I would appreciate it.
MY PROBLEM
There are 4 fittings on the throttle body as well as the throttle electrical connector.
Knowing 2 of them are to bring in warm water to prevent the throttle body from frosting up (freezing) in cold climates and higher altitudes.
1 is for connection to the vacuum switch, my assumption is this one is the main working vacuum source for the car.
What is the 4th fitting for? Is it connected in a Turbo setup? If not should it be plugged or left open?
Could it be the main vacuum connection is below throttle butterfly and the other above?
List of ports
1. Water in
2. Water out
3. Main Vacuum Port
4. ?????????
I would appreciate your knowledge if you have sorted this out
Old Oct 20, 2011 | 07:17 PM
PeArLwHiTe07tC's Avatar
the one closest to the intake manifold is the one for ur vaccum source. im checking to see where the other goes to for ya.
Old Oct 20, 2011 | 07:41 PM
that second one goes to a surge tank. looks almost like the vsv i believe under the intake mani or somewhere in that general area and runs into another hose. hope this helped.
Old Oct 20, 2011 | 10:20 PM
maple's Avatar
Thanks for confirming on your setup.
Old Oct 21, 2011 | 03:16 PM
crush02342002's Avatar
Old Oct 21, 2011 | 03:19 PM
some are a little different but all are just a sorta vent. some just have a hose on it ran just under the intake manifold.
Old Oct 21, 2011 | 07:30 PM
maple's Avatar
Thanks all for responding to my post, so if its a vent it can be open to air pressure (maybe a condensation drain) and not plugged in a Turbo setup, my concern was it could effect tuning or worse yet be a vacuum leak if not plugged. With the amazing electrical diagrams provided, cant understand why Scion does not provide a vacuum diagram by year.
Thanks Again
gedster314
14
Nov 17, 2018 02:56 PM
rancur3p1c
Jul 12, 2015 07:59 PM
scion86
Jul 6, 2015 03:27 PM
A1_Fares
Regional - Pacific Mid
Jul 6, 2015 02:48 AM
Greg S
Feb 19, 2015 07:17 PM
