How to fix/prevent oil line leaks?
Old Oct 21, 2011 | 09:56 AM
gqdabien's Avatar
Default How to fix/prevent oil line leaks?
I seem to be getting various oil leakage around the oil pressure sender and s/c oil feed lines. What is a good way to fix these?
I am thinking of putting some RTV silicone on the threads before reattaching the lines.
Also is it safe to use simple green to clean down an engine bay? I know not to spray directly on electrical related plugs / wires.
Old Oct 25, 2011 | 08:24 PM
PeArLwHiTe07tC's Avatar
u shouldnt have any leaks from the sender at all as well as the feed lines. u should be able to just tighten them enough so that it seals. i would think u have something else goin on ie. bad line, loose fitting or something like that. i wouldnt use any kind of sealant on ur oil feed. any little particle that gets in there will cause a major catastrophe. double check ur lines and make sure that its the line itself thats leaking.
as for simple green, u can use it, but i would use brake clean instead since u dont have to use water on ur bay or electrical connectors.
DaBlackBox
134
Apr 10, 2022 02:04 PM
Brammi
Nov 13, 2016 03:46 AM
my06tc
Jun 25, 2015 12:18 AM
08bakerXxtc
Mar 19, 2015 09:51 AM
DougC
Feb 22, 2015 02:39 PM
