New to scion and imports
Old Oct 27, 2011 | 09:21 PM
DieselDragster99's Avatar
Default New to scion and imports
As u can see in my sig I have a good amount of mechanical experience, but I'm clueless on this scion the I acquired through my fiancé getting a new car. My questions are what type of weakness does the car have like with my dodge it was the auto trans, and who's a good reputable company to do business with I just read the very long 56pg thread about ZPI from 05 Wow! I appreciate any input.
Thanks kyle
Old Oct 27, 2011 | 11:48 PM
borderguy881's Avatar
The only weaknesses are:
The ecu is not tuneable without a piggyback or full standalone
The auto trans can't take much abuse when boosted
The manual trans starts to have issues when above about 350wtq and wheel spin
The car cannot be made quick without forced induction
Great companies are ptuning.com , dezod.com and world racing/descendant
Old Oct 27, 2011 | 11:58 PM
tomb302's Avatar
Welcome to the Life My Friend Enjoy your Stay.
Old Oct 28, 2011 | 12:48 AM
Thanks for the input guys. I got a stock hx35 from cummins maybe I can work that in somewhere down the line
Old Oct 28, 2011 | 04:07 AM
mrexotica's Avatar
Welcome.
I've built my '06 tC into a successful auto crosser.
The tC has outstanding suspension.
Also, for a four banger, the tC motor has decent torque.
The only down side I've found is like somebody already said, Toyota's ECU is non-tunable, however, it is a learning ECU
Old Oct 28, 2011 | 07:16 PM
PeArLwHiTe07tC's Avatar
welcome aboard. to start, these cars are great. the 2az platform is a great motor and good power can be made out of em. 1st off depending on how much power ur gonna make, id say ditch the auto trans and do a manual swap. second, imho dezod would be the way to go (not bashing the other companies as they have good products) but dezod is a joy to deal with and theyre very helpful and knowledgeable. there are some go to guys on this forum as well. alot have the experience as well as alot of trial and error. just stick to the basics with the tc. altho some things may be tempermental w the tc, theyre not that complex. u should be able to find just about nething u need on here and if ya cant find it, post a thread and most of us will be glad to help the best way we can.
Old Oct 28, 2011 | 07:36 PM
Pearl you know I used to rag on dezod a lot and favor ptuning but now that I think bout it they both have a lot to bring to the table but dezod does linger around and help the forums with issues jokingly I say maybe he just doesn't have anything else to do all day but I know they are busy out there
Old Oct 28, 2011 | 07:46 PM
Well im planning on putting a full exhaust and intake on to start with, but im not sure were to go after that will a set of 440cc injectors be too much or should i put some kind of engine management on first?
Old Oct 28, 2011 | 07:47 PM
How much power can the auto trans handle?
Old Oct 28, 2011 | 08:04 PM
skinnayyy's Avatar
Team Scionara
you can can a couple things for the trans that will make hold 250 pretty solidly.
and 440cc injectors would be pretty pointless on just an intake and exhaust.
Old Oct 28, 2011 | 08:14 PM
Why is that cause in my diesel world more fuel and air = more power? Is 440 just not enough? Thanks for all the help guys.
Old Oct 28, 2011 | 08:20 PM
twitchion's Avatar
your diesel has the air to make up for the added fuel. It has a turbo, right? When you put the larger injectors on here, without forced induction, your just adding the fuel. imo pointless
Old Oct 28, 2011 | 08:24 PM
Injectors will do no good unless you are turbo or making over 220 hp the factory injectors flow more than enough fuel to feed any natural aspirated modification
And as I stated before auto trans is good for 250 after that you get shift problems some have had luck and run 300hp others not so lucky
Old Oct 28, 2011 | 08:30 PM
With gas engines you want a perfect balance of air to fuel ratio and only when your takin in so much as is when more fuel is needed. With diesel the more fuel you put in the more air the engine will draw do you understand what I saying
@ border...i consider it staying involved within ur demographic.
as for adding 440 injectors, its pointless on a n/a tc. its not gonna make a difference whether u have some sort of management or not. the purpose of ppl using the 440's was due to the supercharger and the trd reflash. adding them without any "forced induction" mod would just be a waste of time and very very minimal gains. u cant feel the difference of 6hp (just for reference~not actual gain). i honestly would wait, save up some cashish and boost it!!! for the almost $1k ur gonna spend on a good intake, header and exhaust, u can either piece together a kit for s lil bit more or u can scrape up a decent kit in the ppc. thats my whole logic on this. i pieced my kit together for under $1500.00 and i made 300whp and 270tq on a stock block. and now i want more, so im building my block and re-doing my turbo setup.
Old Oct 28, 2011 | 08:32 PM
not to mention that the factory ecu will only output so much fuel.
Old Oct 29, 2011 | 12:38 AM
How big of a turbo are you using? I have an HX35 in my garage but im pretty sure thats probably way to big for street use.
Old Oct 29, 2011 | 12:51 AM
Is there anything i can do to upgrade the auto trans is there HD rebuild kits available HD valve bodies?
Old Oct 29, 2011 | 12:59 AM
bdis3's Avatar
Yes, but if you want to make any kind of power, swap the 5 speed in it. Search around the forum. There are stickys related to all your questions.
Old Oct 29, 2011 | 01:48 AM
thendawg's Avatar
HX35 wouldnt be a bad idea if you were going for 500+, I actually considered one, but went with the 6262. To get any type of decent spool, you have to find one with a smaller exhaust housing Oh and yes, for any kind of real power, swap to a 5spd. I blew my auto up within 3 months with 260whp.
umnitza
Dec 1, 2014 06:26 PM
ScionLife Editor
Nov 20, 2014 05:20 PM
roo
18
Oct 8, 2003 05:04 AM
Male_Nurse
Sep 27, 2003 10:59 AM
