View Full Version : seafoam question
shastylz
10-28-2011, 08:06 PM
Im about ready to sea foam engine thru a vacuum hose which hose do i use?
i think it is the pcv hose am i right or wrong
Yang
10-28-2011, 10:05 PM
most people like to use the brake booster line...
When you sea form be sure that the engine is hot.. otherwise it won't be as effective...
If you have further questions there's lots of how to's on youtube with sea foam
r2d2michael
10-29-2011, 05:47 AM
its fun when you drive it right after....fog up the whole place lol i just pourn it in gas oil and spry it into intake wile running
Zillon
11-06-2011, 02:04 AM
Another tip: Don't pour it in so fast that the engine stalls; you'll hydrolock it and possibly damage the engine. Let it suck the seafoam into the line, and then when the can is empty, kill the engine and let it sit for 30 mins.
Start it up after the 30 mins has passed and enjoy the smokescreen.
Also, I recommend using the brake booster line.
Sciond
11-19-2011, 11:26 AM
the above is correct except it staes to use a bit less than a full can..pour the rest in the gas tank...
BTW prepare for neighborhood LULZ
joey3002
12-03-2011, 03:16 AM
I just did mine tonight.. Smoked the whole block around my house.
Just a quick fyi... 1/3 in the brake booster, 1/3 in crank case.. And last 3Rd in gas.
You should do oil change after you put in crank case.. I drove it about 25 miles tonight. Oil and plugs getting done tomorrow morning.
Sent from my htc evo using tapatalk
